Front dually hub/rotor ass.
Ford never made a DRW truck from the factory with a dually bed. The ones you see like my have all been converted. Most of them have been done by a conversion company like centurion conversion. They were bad about using wheel spacer my had them on it when I bought it. I changed them to the factory hubs off of a cab & chassis.
Here is one of centurion conversion trucks
Thanks, I have owed this truck since 1999 probably be buried in it.LOL
There was one on craiglist not to long ago (this is what you are looking for a dana 60) I think in North Carolina. They had the whole truck and was parting it out. Just a head's up the rear axle under a cab & chassis will not work under a pickup it is narrower and the springs are narrower.
Thanks for the pointers regarding the width.
I'm toying with the idea of putting a single rear wheel rear diff under it, and then putting wide tires, low profile on it. Not sure yet, though. This truck is just a toy that will never do a day's work again, so I have a bit of leeway on it's future.
I've just recently thought about working on this truck - I'll have to take a good look and some measurement when it's NOT completely surrounded by snow that's 7 feet deep, with a temperature of -30 (metric or USA...that's cold!).
You can put a 2wd dually rear under it. That is what's under my kind of a Johnny Cash truck I guess you could say a piece of this truck and a piece of that truck.LOL
It's got a dually rear diff under it now. I have enough parts laying around I have several options though. If I find tires that are wide enough to fill the space, I could either leave the dually diff on it, or change to single.
I drive a Kenworth & pull a triple axle 45' trailer for a living. Never tried the super singles cuz they weren't welcomed with open arms here in Canada. But I do know what happens when a trailer tire blows suddenly - $400 aluminum rim, several hundred dollars in tire replacement, $450 fender (or worse). Entire corner of trailer can look like a train hit it. With this Cabriolet having a completely Fiberglas deck...if a super single went pop, the back end of my truck would cease to exist, and likely wouldn't be fixable.
#28
I have several sets of the factory dually hubs if you need them. PM me
Or I have a Complete pkg too
https://www.ford-trucks.com/forums/1...rsion-pkg.html
here is what they look like(top of pic)
#29
#30
