Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Why is My Frame Squeaking?
Guide to diagnose trouble and recommended solutions
Squealing Noise. Only when i accelerate.
hey guys i have a 2002 F250 5.4. 149,883 miles.. When i accelerate all i can hear is a squealing noise. its annoying as hell. as soon as i take my foot off the gas it stops.. it sounds like a loss clamp on my exhaust but its not there all tight.. i cant find it anyone have ideas.. any places a can grease maybe..? its coming from the cab back. not in the front end.
Not in the front... Its not how hard i accelerate it just does it when i put any pressure on it. it squeals louder in first and second then quiets down at a low rpm.. its weird it comes and goes.. but its been doing its alot lately. i feel like something is looss im gonna have to get another hand this weekend and FIND IT! btw just drove 10 miles and it didnt make it.. but it did all day today
That takes the rear part of the drivetrain out of the equation. Have you ever replaced the idler pulley or belt tensioner? I've had those go on my 2000, started out as an intermittant squeal but then became worse over time... They're pretty inexpensive to replace if you go that route (might as well do the belt too if you end up replacing).
Mine ended up being the U joints on the back drive shaft. Replaced them and no more noise !!!
I did the job myself. The U joints cost about $12 a peice. I didn't use a press I had a ball joint C clamp I used and had no problem at all.
