No DTC's on Scangauge II with 6.0??? - Ford Truck Enthusiasts Forums
Old 09-12-2011, 05:53 PM
vwgtiman vwgtiman is offline
vwgtiman is starting off with a positive reputation.
I purchased a Scangauge II to ck DTC's on my 04 Excursion 6.0. I was unable to pull any but upon taking the Ex to the dealer they instantly pulled (3) codes... One for a MAF, one for the glow plug module, and one for the EGR (i unplugged it...). Why didnt the ScangaugeII tell me any of these? I was fooled into thinking this device was compatible w/ the 6.0 PSD. Here is something I also found while on a hunt for info:
The Ford Powerstroke Diesel loosely follows the On Board Diagnostic system known as OBD/II (OBD-2). Because the PSD is weight rated above 8800lbs, the vehicle is not required to follow the structure exactly. Ford uses their own "manufacturer specific" coding system that follows the OBD/II template.
Because of the 8800lb exemption, many generic OBD/II code readers cannot retrieve the manufacturer codes from the computer.
Is this true??? If so, I feel we are being mislead. FYI: The MAF pigtail and the glowplug module were bad...
Old 09-12-2011, 06:05 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Basicaly the scan gauge isnt a very good code reader but should get most generic codes but has a harder time with Dealer Specific codes
Most of us that use a SG use it for the Live PID Data capabilities all rthe X-gauges
have you programed any x-gauges yet
the SG is probably more compatible with a 6.0 than any other make that it covers
there are better code readers/scanners out there just depends how much$$$ you want to throw at it
Old 09-12-2011, 06:11 PM
No ScangaugeII DTC's
Thanks for the quick reply. Yes, I have a few xgauges in it so far. I like it for the gauges however based on what I read on the box and on the website I was led to believe it would tell me more... now I know different.
Old 09-12-2011, 06:27 PM
BLADE35's Avatar
you can get an Auto Enginuty with the Ford Bundle and it will see all codes turn things off/on for testing also do cylinder balance test and a ton more
Its a very powerful Diagnostic tool for around 400.00 All the guys that have them seem to like it
2004 Ford E250 4.6 V8 trouble codes rustyandleaking 1968-2013 Full Size Vans 3 12-30-2016 02:16 PM
Cold out and the 6.0 is acting up. Could use some advice. Godzillamax 6.0L Power Stroke Diesel 13 12-23-2016 04:53 AM
New 6.7L F350 with CEL and P24DA code Mystic_Cobra 6.7L Power Stroke Diesel 23 03-29-2015 10:54 AM
EEC-IV or OBD-II? CT 1987 - 1996 F150 & Larger F-Series Trucks 17 08-29-2011 01:07 PM
EasyOBDII Software / OBD-2 Software gearloose1 1999 to 2016 Super Duty 3 01-18-2011 03:42 PM
Tags
2003, 60, 60dieselscangaugeii, diesel, dtc, ford, gauge, ii, power, scan, scangauge, scanguage, transmission, unable, wt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
