79, 302 Compression test #'s
Just did the compression test on my truck. It’s a 79 302 all stock.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Just want to know if the results are ok or bad?<o></o>
<TABLE style="WIDTH: 192pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=256><COLGROUP><COL style="WIDTH: 48pt" span=4 width=64><TBODY><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; HEIGHT: 15pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" height=20 width=64></TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" width=64>Pistons</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" width=64>Pistons</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" width=64></TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 15pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 height=20 align=right>120</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>4</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>8</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>112</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 15pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 height=20 align=right>120</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>3</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>7</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>110</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 15pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 height=20 align=right>120</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>2</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>6</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>105</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 15pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 height=20 align=right>118</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>1</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>5</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 align=right>110</TD></TR></TBODY></TABLE>
The truck needs to pass the Cali smog test and I know it needs new exhaust cat/muffler included. Just trying to see if it’s going to need more internal engine work then why waste money on exhaust right now.<o></o>
<o></o>
The difference between low and high readings is 12.5%. Was test done while the engine was cold or hot? Did you have all of the plugs removed while you checked each cylinder? Doing a hot test is better. After doing this i would do a wet test where you squirt motor oil in one cylinder at a time to see if the readings come up, does not take much oil. If they all come up about the same, this means the rings are evenly worn, the more a reading comes up over the other ones indicates worn rings on the piston, the oil helps seal between piston and cylinder for test purposes. There is a certain % between low and high to help determine engine rebuilding. Does the engine have a skip? Someone on here should post the %. I can not remember it right now. I will look through my notes in case no one posts.
BeauF0RD
05-02-2017 06:53 AM
FirstInFright
05-03-2016 08:29 AM
TheNomad
06-18-2008 08:35 PM
Jims1969F250
02-01-2007 12:16 AM
