Another morning hard start
where wouldbe a diffrent storey
It would be hard to air test with shop air the HPO that sees 3000 PSI Regular
motocraft oil filter
have you checked the oil filter drainback valve make shure its not stuck open
I have a motorcraft oil filter in it. Ill check the drainplug tomorrow make sure its not stuck. Probably talk with the guys that work on all our fleet vehicles that have a 6.0. They might be able to help me if me or someone else cant find that one thread cheezit is talking about. In any case thanks for yalls help as always.
I have been backing my truck up my driveway at night and at work backing up onto the curb to keep the front end of the truck lower. Starts as normal and runs fine. I figure this is the best thing to do until I figure out what the problem is. So far have new oil (Rotella Synthetic 5w40), new oil filter (Motorcraft), new fuel filters (International). I pulled the oil filter to check the drain back valve and didn't see anthing unusual. I am going to check it again to make sure. Someone said that a diagnostic test most likely would not show anything. I am stumped at this point. Hopefully someone will chime in with a fix. I talked to one mechanic and he said it sounds like the LPOP is about to take a puke. From what I have read though, the HPOP would be more likely the issue. Any thoughts on that?
Thanks to all who have contributed to this post.
on
a scan tool really wont get you there. that the whole issue. an oil pressure guage may or may not.
It got me an idea of what to from there though..
I took the oil cooler out and filled the hpop resovior up with oil and check the leve after a few hours. I found the level had droped by about 40-50%. from there I pulled the pump and block of the supply rifle and refilled the hpop resivior. level stayed full. process of elimanation, a little luck and some experance.
I saw that but then a couple of other post said that wouldn't tell me anything. I am willing to try anything at this point. Is the Scan guage 2 the one I need to get to run these test? I think they run about $160 or so on Ebay? Thanks for your help.
Do you have Cheezit on ignore or what??? You couldn't ask for any better diagnostic help for a VERY difficult problem.
That's almost laughable Moe!!!
#28
That's true in my experience as well... Lost an EGR cooler, no code. Lost HPOP, no code. Lost alternator, no code. Lost 4 injectors, no code.
BUT... I have a Scan Gauge II (post EGR cooler rupture) that I picked up from EBay and it has been extremely effective in diagnosis. Had I had one before the EGR cooler, I probably would have seen that coming. The Scan Gauge can monitor critical items such as engine oil temp, HPO pressure, IPR valve duty cycle, ICP voltages, boost (03 & 04 trucks have no boost gauge), and tons of over stuff. It also will pick up most codes, but not all.
It sounds to me like your truck is definitely experiencing HPO issues. You could also pay Ford dealer to run diags on your truck and then fix it yourself. My dealer charges $85 for a diag, very reasonable. Again, the guys in the shop at the dealer work on these vehicles and will usually have a good idea if your are thorough in your description of the problem. They don't have x-ray vision, but the diagnostic equipment comes pretty close.
If you go the Scan Gauge route - there are several folks here that will help you with diagnosing. Troubleshooting is the process of ruling things out that it could not be until you find what it is. Some folks like to jump to what they think it is and that becomes costly when the problem is still there.
Most likely you won't find a code, but through the process of elimination you will find it and fix it.
#29
#30
