Help: Jumping from a diesel to V10.
Hey all,
Currently have a 2008 F450 diesel and thinking about a chassis/cab F550 V10. The truck is used for towing only (gooseneck horse trailer 12,000-14,000 lbs). Only average 5k per year in miles. Getting tired of the DPF on the diesel, constant regens, making oil etc. Wonder if now is the time to jump out and go gas. Anyone tow something similar to my combo in a F550 V10?
Thanks,
Alan
Thanks,
Alan
Hey all,
Thanks,
Alan
Thanks,
Alan
Downpipe back cat/dpf delete, spartan tuner, Cold air intake = about $1,500 give or take, and no more regens, making oil, etc and a beast of a truck well capable of doing what you're doing. And you already own it.
Yeah and that DPF delete crap is illegal for on-road use and will void your powertrain warrenty also. But that rarely ever gets mentioned.
There is a fellow on here that has two F-550 V10 tow trucks. I'm sure he will chime in. If not I'll find his UN and send it to you so you can ask him some questions.
Oh please, it gets mentioned all the time. And yes, it "may" void your warranty, depending on the dealer involved and what goes wrong.
And I know, there a a slew of stories about somebody that knew somebody whose uncles cousin got busted by The Man for deleting his crap.
If you live somewhere that has smog tests (or might have them in the future) do your homework before doing a DPF delete. The Colorado front range didn't used to smog light truck diesels, now they do. In an area like mine you'd have to run two exhausts systems, one with DPF and one without, switching them for the emissions test.
I just did what you did..I had a 2008 gmc sierra diesel duramax and just sold it. now I have a 2008 f250 v10 crew cab 4x4 with 4.10 gears. I tow a 7k boat and I have to say with a 14k load I would stick with the diesel. my truck is adequate for the 7k, but i literally couldn't feel any lack of power or much of a difference when towing with the gmc when hooked to the boat. but the v10 tows 7k nice enough and i can maintain 65 on the steepest of grades no problem. I also dont tow alot so the gas benefit was better as i was sick of the fuel filters, allison filters, giant oil changes etc. etc. I love my v10 and the switch worked for me- especially since an overpriced ford oil change was only 29 dollars! the gmc was $100 and more for fuel filter every 15k miles etc. etc.
the F550 with a v10 is going to be ridiculously slow let alone with 14k behind it. I am sure it will get the job done but that's a lot of truck and weight for that engine. my v10 is slow- unloaded!
If you reflash the pcm and remove a mandated piece of emissions equipment. Your powertrain warrenty is void, period. Any person or dealer who knowingly replaces related components under warrenty is commiting fraud. Thats partly why Ford cracked down on this crap with encrypted pcms on certain models.
Calling LSchicago2...
You won't like the power or the mileage towing that heavy with the V10, we have a 450 CC with the 4.88's and it is not fun towing that much and more. You'll be in the 22K-24K ballpark total, depending on your terrain you'll be in mid to high single digits with mileage and may or may not be able to go the speed limit. If you are doing short trips on flat ground you may not mind.
Where is Lloyd he will give you the low down on the V-10s.
I have a F-450 with a 6.0 the truck is okay, I should have bought a V-10 when I had the chance.
The newer diesel trucks are not worth it even a 6.0 for my truck it is 168 dollars for a oil change. That is a filter and Delo 400 5w-40 synthetic gets a little expensive after awhile. Truck maxes out a 12mpg empty she won't get any better fuel economy than that.
I'am also paying 5.14 for a gallon of diesel fuel the fun and joys of living in Canada eh.
Own a gasser truck a V-10 oil change would be less than 50 dollars, regular gas is 4.77 a gallon the V-10 gets about 10mpg in a F-450/550 truck.
You should be fine with the V10 then. The V10 F550 will downshift on the bigger hills, but it will pull well in your region. The V10 likes to rev compared to a diesel.
