Wire identification questions
I have several wires under the dash that aren't connected to anything, hoping someone can tell me what they are supposed to be plugged into.
1. black/yellow stripe wire, yellow 3-prong female connector. What is it for?
2. Just below and to the left of the yellow connector, black female connector 2 black wires going into it
3. White/red stripe and black/yellow stripe to green connector. After green connector, blue/red stripe and black wire, both wires are cut. Black wire has molded rubber/plastic thing that the wire goes through in the upper right of picture. Black wire is ground, blue/red is key-on power. 99% sure this is for the radio but just want to check also what is the black rubber thing?
4. Green/yellow stripe to female bullet connector. A thicker green/yellow wire comes out of the lighter goes to another connector and this wire comes out of that. It is always-on power. Are these wires for options I don't have?
1. is a keyed acc. feed there could be 1 or none going to this depending on what year you have
2. not sure don't see it on my 78'
3. your right on the radio- but yellow/black is + blue/red is the illumination + ground goes from radio to behind the istrument panel to a screw on the column support
4. would be a constant acc feed like cigarette lighter and glove box ill. or vanity mirror on visor on XLT
supercabfreak - yeah, I know. I'm not really worried about it, just curious. Previous owner(s) did a hack job all over this truck so just trying to figure out what's what. The radio that was in the truck wasn't hooked up so I'm going to put in a new one which is what started this. Also found a red wire that was just wrapped around other wires and not connected to anything on either end (pretty sure it was for a stereo that was added then taken out)
kingford72 - Thanks a lot
Do you have any idea what that black rubber thing is on the black wire for the radio?
FYI I have 77 f150 custom 2wd, no options except gauges instead of idiot lights
Glenn Nall
04-19-2018 07:04 AM
Davetruck
06-21-2015 04:18 AM
dotcentral
01-10-2004 12:32 AM
