Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-11-2011, 04:48 PM
joiseystud joiseystud is offline
2007 Ford Expedition
joiseystud is starting off with a positive reputation.
2007 Expy trailer lights not working
I have a 2007 expy with the tow package. I plugged in a trailer and no lights work whatsoever. I checked the fuses and they are all good. Anyone have any ideas? Can someone email me a wiring diagram for this part of the electrical system? my email is justin at constructpoint.com
thanks in advance.
  #2 (permalink)
Old 09-11-2011, 06:20 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
which harness are you trying to use?
the 4 pin or the 7 pin?
if the 7 pin, sometimes you have to connect the trickle charge wiring and there is a relay that gets used. For some reason some Fords already have it connected, and some don't
edit: otherwise, you need to check voltages
you can get a cheap voltmeter for about $10-15 at Walmart/Parts Store. At the connector itself, check for voltage.
Also, check your trailer wiring itself. If the pins are corroded, or improperly grounded you won't get any lights
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 09-11-2011, 09:55 PM
I tried it on both the 4 pin and the 7 pin with an adapter (trailer was 4 pin). I need a wiring diagram to know what the meter should be reading. Maybe its a relay problem. Need diagram to troubleshoot.
We tried the trailer on my cousin's Suburban and the trailer works. It was embarassing that my Ford ultimately couldnt trailer the boat and we had to use his truck.
  #4 (permalink)
Old 09-12-2011, 03:47 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
Ford follows the standard wiring convention for 4 pin connectors. I went out and checked my Expy and F-250. They both follow the same color pattern
ground - White wire
left - Yellow wire
right - Green wire
brake - Brown wire
here is a good diagram for the standard trailer wiring setup
Trailer Wiring Diagrams | etrailer.com
__________________
  #5 (permalink)
Old 09-13-2011, 06:56 PM
dgruhlke dgruhlke is offline
dgruhlke is starting off with a positive reputation.
Quote:
thanks in advance.
Check the truck wiring where it plugs into the back of the 7-pin. The connector on my 07 expy was not fully seated in the back of the 7-pin plug.
  #6 (permalink)
Old 09-18-2011, 08:55 AM
ground - White wire
left - Yellow wire
right - Green wire
brake - Brown wire
Thanks. I was looking more for the internal wiring in the truck from the trailer connector to the fuses/relays, etc.
  #7 (permalink)
Old 09-18-2011, 09:04 AM
Wasnt getting any voltage from ground to the running light pin on my Fluke. Went through all fuses and they were good. I pulled the relay for the parking lights and swapped it with the starter relay. Then I got voltage at the trailer connector. I swapped the relays back to double check but now the old relay worked. Im not sure if the relay just didnt have a good connection or there is an intermittent issue in the relay. I kept it swapped with the starter relay figuring it will be used very often and if it fails it will be obvious and I can always swap it back so I wouldnt be stranded. I will price this out and if its cheap enough will just order the replacemnt relay.
I am unclear how this would affect turn signals though. It would seem to me the only thing that should affect all of the items is if there is a ground issue.
  #8 (permalink)
Old 09-18-2011, 12:32 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
no idea man...sometimes electrical stuff is just confusing. there might have been some slight corrosion on the contacts. just you moving the relays around cleaned them up?
I wouldn't question it. It might blow up in your face
__________________
Tags
1997, 2010, connected, expedition, f150, ford, lighnts, light, lights, lincoln, navigator, tow, trailer, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
