Anybody know the size of the starter bolts - Ford Truck Enthusiasts Forums
Old 09-11-2011, 03:30 PM
radmacks's Avatar
radmacks radmacks is offline
radmacks has a good reputation on FTE.radmacks has a good reputation on FTE.
Does anybody know what the size of the starter bolts are, my bolts rattled loose the bottom one came out and the housing broke, the bottom bolt is gone and I need to find a new one ASAP, as well I'm in Canada any suggestions where I could find a new one ?
Old 09-11-2011, 05:02 PM
radmacks's Avatar
And to make things even more confusing my starter is two bolt but I see the mount has three threaded holes. Does a 2002 7.3l take a 2 bolt or 3 bolt starter ?
Old 09-11-2011, 06:24 PM
lhud lhud is offline
lhud is gaining momentum as a positive member of FTE.lhud is gaining momentum as a positive member of FTE.
Mine is a two bolt setup. It also has a third hole for a three bolt setup as well.
My starter did not have room for a third bolt.
I do not know the metric size of the bolts, but I think maybe the socket size was a minimum of 10 mm - really just guessing from memory.
Maybe someone else will clarify for you.
Try searching through some of the existing starter threads. I also remember someone having to replace the adapter plate that allows the starter to be bolted to the engine.
Good luck,
Old 09-11-2011, 06:40 PM
radmacks's Avatar
After searching and searching I have come to the conclusion that we can use both 2 or 3 bolt, Mitsubishi seems to be the only one making three bolts. The bolt sizes are M10 x 1.5 x 35mm grade 8.8. I'm going to clean the holes with some break cleaner and then try some loctite red on them and see how it goes.
Starter bolt size Badboy4wd 1999 - 2003 7.3L Power Stroke Diesel 12 10-16-2016 12:16 PM
Starter bolt size, 70 f-100 390 engine 70-360fe 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-11-2013 11:00 PM
99 7.3 Starter Bolt Socket Size? Yougotthehit 1999 - 2003 7.3L Power Stroke Diesel 7 01-19-2012 12:07 AM
Nuts on Starter- What size are they? Judd944 1997 - 2003 F150 1 05-03-2011 08:41 PM
Starter bolts MikePacey 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-11-2011 12:14 PM
Tags
351m, 400, 460, 60, 73, bolt, bolts, diesel, f250, ford, metric, power, size, sizes, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
