Hot start problem: 6.0L - Ford Truck Enthusiasts Forums
Old 09-11-2011, 03:11 PM
shane90dsm shane90dsm is offline
shane90dsm is starting off with a positive reputation.
I have a 2006 turbo D 6.0L and this week I started to get a hot start problem. The truck starts ok when cold, go the store, turn off; go to start and it just cranks. Came up with a p2290 fault code. Injector control pressure too low.
From what i looked up was, it can be a number of things. High Pressure oil pump etc. Could this be a fuel pump issue? I replaced the glow plug control box, and im going to replace the FICM next. Im also going to change the fuel filters in hope that its an easy fix.
any other ideas?
Old 09-11-2011, 03:14 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
any other ideas?
Id hold off on a new FICM maybe just check th volts on it
P2290 is your Hgh Pres Oil system start there
Your drivability issues are from a Bad STC fitting,standpipes,and dummey plugs
Your HPOP is Fine
change above mentioned and problem will be solved when you change those parts on your HPO system
this is very common on an 05+
Old 09-11-2011, 03:46 PM
Your HPOP is Fine
Thanks man. I was worried about that. This is an ambulance aplication and i have a spare ambulance that is over miles. (no longer able to funcion as an ambulance) so i took the FICM off of it. But i guess i don't even have to worry about that now.
Old 09-11-2011, 04:14 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
What benny said. Your problem is going to be in the hpo system. Most likely the stc fitting.
Old 09-11-2011, 06:03 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quite possibly not the stc. Those problems were mainly in the 05 models. Check 1st by unplugging your icp connector. That sounds more like your problem on an 06. Then you can look further. Simple things first.
Old 09-11-2011, 10:12 PM
Coronado's Avatar
Coronado Coronado is offline
Coronado is starting off with a positive reputation.
Quote:
He speaks the truth, true diagnosis is the key to any problem on modern vehicles/equipment. Besides, you learn nothing when you just throw parts at something.
Old 09-11-2011, 10:21 PM
texans's Avatar
I agree with both post above. I would never suggest throwing parts at anything. You will need some sort of a scanner that can read pids to help diagnose this. Scan gauge II from autozone is a good choise for this on a budget. Or go with autoenginuity with ford enhacements a little more pricy, but great tool to have.
I would not suspect the icp with a hot no-start situation, but you never know. Typically this situation is due to a leak in the hpo system somewhere. Either way you will need a way to verify hpop at time of no start. As 69cj said try unplugging the icp sensor next time it happens and try to start.
Old 09-11-2011, 10:29 PM
Coronado's Avatar
If you happen to be located someone near north Texas then I would be more than willing to meet you and help diagnose your problems!
Old 09-11-2011, 11:24 PM
BLADE35's Avatar
Quote:
Gauges would be a great start as Scotty said
I use SGII although AE would be awesome
I really hope its as easy as a New ICP Sensor
just thought there would be diffrent symtoms and diffrent code
The only parts I recomended went along with his P2290
Old 09-12-2011, 10:59 AM
Thank you guys for all the posts. I might have to just take it to the dealer. When the truck runs it seams to run ok, no loss in power ect. but turn it off.... anyways. I think there may be a new leak somewhere. Im going to look up how hard it is to replace the STC fitting. one thing to keep in mind is although it is an 06 it might be an 05 engine. It takes time to build the box on the back. And not sure about year splits ect. but again thanks guys.
Old 09-12-2011, 11:25 AM
egregg57's Avatar
egregg57 egregg57 is offline
egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.
You're describing what was happening to my truck. It's an 05 though. Had to have the fitting replaced on the HPOP. All set now.
Weak hpop? High Pressure oil leak? BstangBill 6.0L Power Stroke Diesel 1 10-31-2016 10:08 PM
2002 F150 Sport Fuel Pump Control Module pocketmaster 1997 - 2003 F150 3 03-14-2016 04:30 PM
2003 6.0 - Hard to start hot. HPOP? benb123 6.0L Power Stroke Diesel 13 10-13-2013 09:29 AM
NO START CONDITION. henryjb3363 6.0L Power Stroke Diesel 26 10-18-2010 05:43 PM
2006 F350 Diesel 6.0L hot re-start problem mpeterson0786 6.0L Power Stroke Diesel 4 07-03-2009 10:18 PM
Tags
60, 60l, 87, dragging, f150, f250, ford, hot, hpo, issues, problem, start, starter, starting, supercharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
