Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 09-11-2011, 09:12 AM
rosenkranswa rosenkranswa is offline
Garage is empty, add now
rosenkranswa is starting off with a positive reputation.
2006 F-250 Super Duty Turbo Diesel Towing Capacity
I have just bought a 2006 F-250 Super Duty with the 6.0 liter turbo diesel, extended cab, short box, factory tow package, 3.73 limited slip axle and LT 265/7OR17E tires. Can I pull my 24' dual axle enclosed auto transport trailer with a max gross of 7700 lbs?
The manual says no, max towing capacity is 5000 lbs, but the GCVW is 23,000 lbs (we're well under that) and I find different numbers on the internet ranging from the 5000 lbs in the manual to 8600 lbs, to 9500 lbs, to 15,000 lbs.
  #2 (permalink)
Old 09-11-2011, 09:47 AM
Lead Head Lead Head is offline
Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.
Are you sure you're not mixing up payload and towing? A Ranger can tow 5,000 pounds....
According to the 2006 Ford Fleet guide, your truck should be good for 12,500 pounds with conventional towing. Fifth wheel brings that up to 16,000 pounds
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #3 (permalink)
Old 09-11-2011, 10:19 AM
XB70 XB70 is offline
XB70 has a good reputation on FTE.XB70 has a good reputation on FTE.
I believe if you have somebody read the manual to you, he or she will explain that conventionally towing trailers exceeding 6,000 lbs. or 600 lbs tongue weight requires an equalizing hitch.
The towing specifications for 6.0 Powerstrokes are in the Diesel Supplement tpo the Owner's Guide.
http://www.motorcraftservice.com/pub.../0660l6d3e.pdf
Please figure it out before driving on public roads!
  #4 (permalink)
Old 09-11-2011, 10:39 AM
Jakebrake's Avatar
Jakebrake Jakebrake is offline
< Samantha...my Co-Pilot
Jakebrake is gaining momentum as a positive member of FTE.Jakebrake is gaining momentum as a positive member of FTE.
You will be fine with a weight distributing (equalizing) hitch.
  #5 (permalink)
Old 09-11-2011, 11:40 AM
Thanks for the replys
OK, thanks for the replys guys. I see in the manual supplement for the diesel that the Max trailer weight with the weight distributing hitch goes up to 12,500 lbs, so I need to get an equalizing hitch.
Now, what would the forum recommend for that hitch? I see a dealer for Equal-i-zer Hitch closeby.
Thanks again all!
  #6 (permalink)
Old 09-11-2011, 11:51 AM
kd0axs's Avatar
kd0axs kd0axs is online now
2005 Ford F-350
kd0axs has a very good reputation on FTE.kd0axs has a very good reputation on FTE.kd0axs has a very good reputation on FTE.kd0axs has a very good reputation on FTE.
I believe what you are reading are the ratings for the factory receiver hitch, which are 5000 lbs with a standard hitch and 12500 lbs with a weight distribution hitch. So, with your trailer of 7700 lbs, you should technically be using a WDH.
However, I will say that I don't think I have ever actually seen anyone using a WDH on anything other than a camper trailer. I see tons of contractors every day pulling around their skid loaders and other equipment and none of them are using a WDH.
  #7 (permalink)
Old 09-11-2011, 11:57 AM
kd0axs's Avatar
2005 Ford F-350
Thanks again all!
Yes, I would recommend a WDH. Even if you don't really need it, (which technically you do) your trailer will pull much better with it.
  #8 (permalink)
Old 09-11-2011, 12:17 PM
Quote:
You believe? Why don't you read instead? The FORD MANUAL states a trailer weight over 6,000 lbs. or 600 lbs. tongue weight requires a weight distributing hitch for a 2006 F250 6.0. I posted the manual.
THE 2006 F250 OWNER'S MANUAL REFERS TO THE DIESEL SUPPLEMENT FOR CORRECT TRAILER TOWING DATA IF THE TRUCK IS EQUIPPED WITH A DIESEL ENGINE.
  #9 (permalink)
Old 09-11-2011, 12:25 PM
carltonwebb's Avatar
carltonwebb carltonwebb is online now
carltonwebb has a very good reputation on FTE.carltonwebb has a very good reputation on FTE.carltonwebb has a very good reputation on FTE.
The e-qua-lizer 4 way is an awesome hitch. i had the old style chain hitch befofe and replaced it with the equalizer and it is a much smoother ride.
__________________
2000 Ford F-250 Supercab, 7.3 PSD, Auto, Bone Stock, 199,400k. 08 SD tailgate.
2011 Ford Escape Limited, V-6, For the wife.
  #10 (permalink)
Old 09-11-2011, 12:58 PM
kd0axs's Avatar
2005 Ford F-350
Well, I didn't feel like downloading a file I don't need because I don't have a diesel. I was simply referring to the ratings of the hitch.
However, I will ask this.....Do the diesels have a different hitch than the gassers? Mine is clearly marked as 5000 lbs without a WDH. Or was this a change from 2005 to 2006?
Click the image to open in full size.
  #11 (permalink)
Old 09-11-2011, 02:02 PM
hotairgypsy hotairgypsy is offline
hotairgypsy is starting off with a positive reputation.
can someone post a pic of this fancy hitch so i know what i am looking for? thanks
  #12 (permalink)
Old 09-11-2011, 02:38 PM
Why don't you read the file you didn't bother to download?
If you bothered to read my post you'd know the weight ratings are different per the owner's manual.
When downloading and reading an already linked file is more difficult than crawling under the wrong truck to take a picture and uploading it to the internet, it says something about our educational system.
  #13 (permalink)
Old 09-11-2011, 02:48 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
Quote:
It's there on your truck!
Sticker is on far left side adjacent to 7/4 pin connections
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #14 (permalink)
Old 09-11-2011, 02:58 PM
Quad Racer's Avatar
Quad Racer Quad Racer is offline
Quad Racer has a great reputation on FTE.Quad Racer has a great reputation on FTE.Quad Racer has a great reputation on FTE.Quad Racer has a great reputation on FTE.Quad Racer has a great reputation on FTE.
Wow, you sound like a royal A** or an engineer or something .
I will say this to the OP though, if your unsure of towing weights like these you probrably shouldn't have bought a diesel or even a SD. The diesel fad strikes again, overkill..................Sorry man jmo.
__________________
08 XLT 250 CC V10 4.10 - 5 Star tunes (giddyup),18"x9" XD Addicts, 295 70 18 Trail Grapplers, Prestige fender flares, side marker lights
2001 E 250 Work beast
Jason
  #15 (permalink)
Old 09-11-2011, 03:55 PM
kd0axs's Avatar
2005 Ford F-350
I didn't need to read it to understand that the tow rating of a diesel is higher. My question was specific to the hitch itself.
Do the diesel trucks have a hitch with a higher rating, or is it the same one that is on the gas trucks? If it's the same one, you would still be limited to the rating of the hitch, even if the truck's tow rating is higher.
Tags
06, 1997, 2004, 2006, 60, capacity, chart, diesel, f250, ford, max, sd, tow, towing, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
