Tune up 5.4L - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Tune up 5.4L
Old 09-11-2011, 01:04 AM
DaGuru373 DaGuru373 is offline
DaGuru373 is starting off with a positive reputation.
Question Tune up 5.4L
He y there fellow Ford fans.......First time changing plugs on my 5.4. Is there any tricks to help this and whats the best way to keep dirt from falling down to the bottom and into the plug hole ??? I cleaned them first as best as possible.. And should I replace the wire springs inside the boots ????? or what suggestions ? I have done many tune ups but FIRST time here on my 5.4L Thanks Jc
Old 09-11-2011, 03:06 AM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Quote:
What year is your truck? Do you have the Windsor or Romeo built engine? Some of the different years and designs have different and unique issues with the plug changes. I suggest that you do a search on plug changes. IMO the coils, springs or boots do not have to be replaced with each tune up but many do as an insurance because this is not a job you want to do more than once per 100,000 miles. It all depends on your gambling instincts and the level of pain you can endure. Tune ups are no longer the fun they were back in the day.
Old 09-11-2011, 11:20 PM
orleec's Avatar
orleec orleec is offline
orleec is starting off with a positive reputation.
When I did mine some 6 years/60k ago, I replaced the coil-on-plug (COP) on the hardest to reach cylinder with a new one (rearmost, passeneger side) and kept the old coil as spare - I have since used that spare as another coil have gone.
Nowadays, a set of coil at eBay costs < $100 and there seems to be no issues with them that I hear of.
So those are your options as I strongly suggest not to re-install the old coil you'll remove on that cyclinder, and arguably on the other side's rearmost cylinder (driver side) as well as they are both PITA to work on, the ps more so.
Compress air if available, otherwise, you can use a 5/8 deep socket with a dab of grease to the end, to get the debris on the plug holes prior to plug removal - you'll have to fish out dirt several times with this method but it will work.
Oem Motorcraft is available in parts store now, although I elected to use double plat Autolite at the time as I could only find oem plugs at stealership then.
1/4-7mm wobble would help, as well as quality 7mm combination with 12 pojnt box-end. Extension assortment, time, lots of patient. Save the beer for when job is done as you'll need to concentrate. If you drop a bolt for the coil, very slim chance you'll find it in the engine abyss, so don't drop any.
GL
Old 09-12-2011, 08:30 PM
eriklynden eriklynden is offline
eriklynden is starting off with a positive reputation.
So i got 205000 miles on the truck has prob never had plugs /coils done but it just doesnt feel right what where ????? Or are the sign of a failing coil. I Checked plug it's Fine
Thanks.
Sry for bad grammar n spelling. Dam this iPad.
Old 09-12-2011, 09:28 PM
max3860 max3860 is offline
max3860 is starting off with a positive reputation.
The best thing I found to get the dirt and crud out of the spark plug holes on all the 5.4 style engines before and after you remove the coil packs and spark plugs is a few feet of 5/16 or larger fuel or vacuum line taped to the end of your shop vac hose. It makes a great little flexible suction hose to vacuum up all the dirt around the coil packs and inside the spark plug holes.
On the 3 valve engines with the long stye spark plugs that tend to break in half, this works really well at sucking up all those pesky little shards of porcelain before and after you have to use the Lisle tool to remove the bottom half of the plug and only costs a few $$.
Any advice on '97 E-150 5.4 tuneup? BMcT 1968-2013 Full Size Vans 13 10-07-2014 07:54 AM
Best plugs for 5.4L docweld 2004 - 2008 F150 22 02-10-2013 03:41 PM
best spark plug? AppocAlexx Modular V8 (4.6L, 5.4L) 9 01-19-2012 08:41 PM
Question About Tune Up 1997 Ford F150 bronco2454 1997 - 2003 F150 4 09-23-2009 06:30 PM
Tune up 99 f250 with 5.4l homersdss 1999 to 2016 Super Duty 12 03-24-2009 07:53 PM
Tags
2003, 2007, 54, cost, engine, expedition, f250, fine, ford, liter, navigator, perform, tune, tuneup, up54l
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
