5.8 Timing Question HELP!! - Ford Truck Enthusiasts Forums
Old 09-11-2011, 01:03 AM
bcorg bcorg is offline
bcorg is starting off with a positive reputation.
I have a 1990 f250 5.8 4X4 that I am getting close to being a daily driver, thanks to the help and advice from this forum. The truck runs very well but after being warmed up and driven a few miles it cranks over hard, almost like a near dead battery. (Battery is brand new.) My search on this forum suggests that my ignition timing might be too far advanced. My Chilton manual seems to indicate that I have the TFI-IV ignition, since it doesn't have a vacuum line to the distributor, and Chilton states that "no ignition timing adjustment is possible and none should be attempted". Do I really have a timing issue and if so, how do I fix it? Thank you in advance for any help!!
Old 09-11-2011, 01:18 AM
timbersteel's Avatar
timbersteel timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Yes you do have a TFI ignition system, but...there is a base tiing that must be achieved. Using a timing light, remove the Spout connector and verify @ the timing pointer that the base timing is 10 degrees BTDC. After verifing base timing, plug the Spout connector back in and verify that it advances. Reading your post, I'm more inclined ot think that perhaps the Ignition coil is to blame. Easy check for this is to let the truck sit several hours to cool down, then use a hair dryer or another means of heating the coil up. Once you have got it warm (Not melted), try to start the truck as you have in the past. Is it hard ot start? If so, the coil is most likely on it's way out and it's far better to replace now, rather than in 18 inches of snow like I had mine go out and couldn't get it figured out, except for your idea of a Dead battery.
Also, you TFI module is located on the distributor itself. These are known to fail due to the amout of stress they endure from the vibration, heat and other factors putting them to the extreme due to the location. Ford revised the TFI module to be located on the Driver side Fenderwell with a large aluminium heatsink. Also, try the hairdryer trick with the TFI module "IF" your diagnosis leads you there, ruling out the coil as the culprit.
Old 09-11-2011, 01:25 AM
Thankyou timbersteel!!! I will check intial timing first. Is the spout connecter the plug on the distributor or somewhere else? I wouldn't think it was the distributor plug but I'm fairly new to Fords. Thank you
Old 09-11-2011, 01:33 AM
On the dizzy-mounted TFI, I believe it located close to the distributor, but I haven't a system like yours to take a pic. My '90 rebuild is identical to yours, but the harness isn't with me right now. RLA2005, maybe Subford has a pic of it, (I've seen it here several times, try searching for Spout Connector, Subford) but it is a grey Spout connector and it may be wrapped in black electrical fabric tape or if someone has accessed it, it will or should be Grey in color.
Old 09-11-2011, 01:40 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Use this for distributor mounted TFI (aka ICM) modules:
courtesy of FordFuelInjection.com
The entire procedure: Ford Fuel Injection Setting the timing
Old 09-11-2011, 01:44 AM
Wow! I didn't think you would be up this late RLA? LOL!
I also included this link showing a pic, courtesy of Subford. RLA, my '90, 302, hasn't got the Spout connector you have shown above, it was just as both of my '92's, 300 and 302.
http://www.ford-trucks.com/forums/10...-question.html
I completely forgot to insert the link earlier...Brain has completely quit functioning @ 1 a.m. Thanks for the diagram RLA2005!
Last edited by timbersteel; 09-11-2011 at 01:53 AM. Reason: Completely FORGOT to add the link!!!
Old 09-11-2011, 01:50 AM
rla2005's Avatar
Here is a line drawing of the remote TFI and spout:
A different pic of a SPOUT for a distributor mounted TFI:
Old 09-11-2011, 01:54 AM
rla2005's Avatar
Insomniac theater.....
Old 09-11-2011, 01:55 AM
Fantastic folks!!!! Thank you very much!!!! I'll start by checking timing and then do the coil test. I'm close to having this truck ready for a daily driver I can trust. Thanks again!!!!
Old 09-11-2011, 01:56 AM
LOL!
Thanks for the pics RLA! I knew that you and Subford had them and the latter one is of mine. Gonna keep this saved in my fav's and save the picture for future reference with courtesy calls for both of you.
In need of a Chilton or Hayes Manual CD Freddie Murphy 1987 - 1996 F150 & Larger F-Series Trucks 1 07-07-2016 05:36 PM
Newbie with a 63 and QUESTIONS schweinhaus 1961 - 1966 F-100 & Larger F-Series Trucks 10 03-28-2015 08:01 AM
Replacing Coil Connector - question... 77beater150 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-25-2014 09:47 PM
1991 F-150 XLT Lariat 4X4 Chilton or Better Freddie Murphy 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-25-2012 10:15 AM
'99 Expy Charging problem THUNDERBOLT5150 Expedition & Navigator 5 04-28-2009 11:34 AM
Tags
1990, 29, 49, 58, 96, bronco, connec, connector, distributor, f150, ford, pickup, pointer, ranger, set, spout, ter, timing, timming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
