Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-10-2011, 10:24 PM
netty628 netty628 is offline
Garage is empty, add now
netty628 is starting off with a positive reputation.
camshaft sensor
I have a 2008 Expedition. Today my engine light came on and I took it to Autozone to get the test run. It came back as a camshaft sensor A bank 2. So my question is, are they hard to replace yourself? My husband was gonna try but he doesnt know alot about cars. I am sure he can figure it out if it is not hard. Thanks
  #2 (permalink)
Old 09-10-2011, 11:08 PM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Welcome to FTE.
I would like to answer the question however I need to know what motor you have in the Ex.
Is it the 5.4L V-8 or the 4.6L 6 cylinder?
In the 5.4L the camshaft position sensor is located in the front end of each head.
It is held in by 1 bolt.
Buy BWD Camshaft Sensor CSS1643 at Advance Auto Parts
Click the image to open in full size.
How To Replace A Camshaft Position Sensor (CMP) - YouTube
I would go ahead and change both of them while I was in there.
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #3 (permalink)
Old 09-10-2011, 11:12 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
1966 Too much Tools
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Remove negative battery cable before removing sensors.
Computer has to go to sleep for at least 15 minutes before
reconnecting battery.
AND it is a safety issue too.
Post your results when the repair is completed!
BTW
Welcome to FTE, netty628.
__________________
Darren
Join the Hawai'i chapter *HERE*
  #4 (permalink)
Old 09-10-2011, 11:15 PM
Hi Shorebird, it is a V8. So with knowing that is this gonna be a difficult job? Thanks
Hi Khadma, thanks for the tips. I will post what happens tomorrow.
  #5 (permalink)
Old 09-11-2011, 12:40 AM
shorebird's Avatar
Wage Slave
2008 Ford F-150
Watch the video and figure out if you can do the job.
http://www.youtube.com/watch?v=AKYjp...ature=youtu.be
For me it is simple. For my wife it is impossible.
__________________
  #6 (permalink)
Old 09-11-2011, 02:13 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
Shorebird, the 2007+ Expy only has the 5.4 3v for the motor. Ford didn't continue the 4.6 2v/3v into it the latest version
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #7 (permalink)
Old 09-11-2011, 06:10 AM
shorebird's Avatar
Wage Slave
2008 Ford F-150
Duly Noted. Thanks Tylus.
__________________
  #8 (permalink)
Old 09-11-2011, 02:40 PM
Yay!! It is all fixed. The part cost me $14. The shop down the street said it was gonna cost about $200 to fix cause it will take about 3 hours to fix. Again, my hubby knows really nothing about cars and it took him less than 10 minutes. Thanks for all the help you guys gave.
  #9 (permalink)
Old 09-11-2011, 02:48 PM
shorebird's Avatar
Wage Slave
2008 Ford F-150
We do what we can.
If there is someone whose post is particularity helpful There is a way to say thanks.
In the upper right of the post there are two red buttons.
The left one is for "Repping" them and the right is for giving a negative.
There is a blue bar across the top of the thread where you can click on "User CP"
That will take you to your personal account info.
Scroll down and you will see where your Rep points and the accompanying notes are listed.
__________________
  #10 (permalink)
Old 09-21-2011, 04:45 PM
Well my engine light came back on again today. Only been about 10 days sinces my hubby replaced the sensor. Another guy helped me at auto zone today. Test came up as same sensor A bank 2. My hubby replaced the drivers side sensor. It worked fine up until today. Could he have replaced the wrong side? Thanks
  #11 (permalink)
Old 09-21-2011, 08:03 PM
shorebird's Avatar
Wage Slave
2008 Ford F-150
There is the possibility that the sensor has failed.
There may be a fault in the circuit wiring that will show as a sensor problem.
A thorough inspection both visually and doing continuity tests for damaged wiring or connectors is needed.
Sometimes a fault may be in a connector and simply disconnecting then reconnecting it may clear the fault.
A connector may have not been completely reconnected by your husband and it has worked loose.
Happens all the time.
__________________
Tags
2004, 2006, 2007, 54, bank, bank2, cam, camshaft, cmp, expedition, f150, f250, ford, sensor, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
