How would i find out the gear ratio? - Ford Truck Enthusiasts Forums
Old 09-10-2011, 09:31 PM
passengerdoorsmud's Avatar
passengerdoorsmud passengerdoorsmud is offline
passengerdoorsmud is starting off with a positive reputation.
I'm 14, just got my first truck. 87 ford f250 4speed 4x4. When we were driving it home we discovered it's geared to pull over a house. In first and second it is slow then when u hit 3rd it goes. where on the truck would i figure out the ratio?
Old 09-10-2011, 09:39 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Drivers side door post there is a tag, post up the axle code here, someone will tell you what it is..
Old 09-10-2011, 10:30 PM
that tags on the back edge right?
Old 09-10-2011, 11:05 PM
right,,,,,,,,,,,,,,
Old 09-11-2011, 08:06 PM
it's got a c9 on it
Old 09-11-2011, 09:19 PM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
there should be a tag on the diff cover...it has the info you are looking for
Old 09-11-2011, 09:33 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
Originally Posted by passengerdoorsmud View Post
it's got a c9 on it
That's 3.55 limited slip.. Ford Axle Code Chart .: Articles
Old 09-12-2011, 09:46 AM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Since a previous owner certainly could have swapped in a different set of gears, here's what I would recommend:
Chock the front wheels, jack the rear of the truck up, and place jackstands under the rear axle. Put the transmission in neutral. Make a mark on the pinion flange (where the driveshaft connects to the rear axle) and a mark on the tire. Rotate the driveshaft and count the number of revolutions it takes to rotate the tire one full revolution.
3 1/4 turns = 3.27's or 3.31's
3 1/2 turns = 3.55's
3 3/4 turns = 3.73's
4 turns = 3.90's or 4.10's
etc. etc.
Old 09-12-2011, 11:28 AM
1987F250460 1987F250460 is offline
1987F250460 is starting off with a positive reputation.
Grear Ratio
Quote:
Mine says C5 on door sticker
Old 09-12-2011, 04:43 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Quote:
Conanski gave you the link to find the answer.
C5 4.10. LIMITED SLIP
</pre>
Old 09-12-2011, 09:45 PM
Thank you
Quote:
I saw the link now thank you very much, I don't understand mine says C5 but it shows a 1991 and showed that 1987's are C9's that's weird ;(.
Old 09-12-2011, 09:47 PM
</PRE>
Thank you, but do you think the years are switched around mine is an 87 not a 91, It shows C5's with 4.10 were 91 yr .
Old 09-12-2011, 09:52 PM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
FYI...1st gear on that 4 speed is "granny gear". You really only need to use this when you need super low gearing for pulling power. 2nd gear is geared like your typical 1st gear, so under normal conditions you start out in 2nd gear, then shift to 3rd and 4th.
Old 09-12-2011, 09:57 PM
Edgethis's Avatar
Well I checked my code and it lists as a 91 year when my truck is a 95. So i don't know about the year. but I assume, the gears are right regardless.
Old 09-12-2011, 10:02 PM
Quote:
I was wondering why the truck didn't go anywere in 1st. gear lol then second was ok and 3rd was good phew thanx I think that will save me alot of gas hehehe.
Need Help Figuring out Gear ratio joeplouff 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-09-2016 09:19 PM
Looking for my gear ratio. Super Dirty Greg 1999 to 2016 Super Duty 13 10-21-2014 03:43 PM
Changing Gear Ratios Daleksandrovich 1987 - 1996 F150 & Larger F-Series Trucks 7 03-22-2014 09:37 AM
Great ZF Trans Table and Gear Ratio Preference Survey OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 19 11-14-2012 09:10 AM
sterling rear end help f1001969mike 1978 - 1996 Big Bronco 4 12-01-2011 09:28 AM
Tags
08, 1979, 1996, 46, 58, 96, determine, f150, f250, figure, find, ford, fseries, gear, ratio, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
