I know I can tap or cut the wires but I would rather get the plug.... so can someone tell me the plug # that plugs into the running board light plug on the 2011 SD?
I was wanting to know the same thing as I would like to do some type of underbody lighting with the doors open. I have a suspicion that you're not going to find these plugs as a stand alone item. They probably only come on the lighted running boards. I'll probably just tap the hot wire so the connector stays intact, and then ground whatever lights I install to their own mounting screws/bolts.
Ive had realy bad luck with lighted running boards. You have to keep ice and snow kicked up by wheels from building up on wires and pulling them out. Repair twice a year
