6.2L V8 Discuss the 6.2L V8
Upgrade Fuel tank to larger capacity
Old 09-10-2011, 06:43 PM
iggy2's Avatar
iggy2
iggy2 is offline
Has anyone thought about adding a large fuel tank?
I've heard of some from past years but nothing about 2011?
I'd be interested in one that was 50 gallon replacment tank.
I found this link for Ford F-250 2011 replacement tanks.
Ford pickup replacement tanks
What do you think?
Old 09-10-2011, 07:00 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Check over in the 6.7 forum, alot of guys have been upgrading the tanks with a Titan tank. Ford finally enabled some parameter changes in the IDS system that allows them to change the tank size so your MTE (miles to empty) is more accurate with a larger tank.
Old 09-10-2011, 09:19 PM
RZAR's Avatar
RZAR
RZAR is offline
I see them made for Diesels but none for gas trucks
Old 09-10-2011, 09:38 PM
dougsale's Avatar
dougsale
dougsale is offline
I replaced the factory 30 gallon tank on my 2010 with a 47 gallon aluminum tank from Transfer Flow Inc. out of Chico CA. Transfer Flow carries tanks for both gas and diesel. My particular configuration (short bed) left me with 47 gallon max tank capacity under the bed of the truck. It cost me $1300 complete and I love it. The only problem you may have is that CA has to test and certify their tanks and that takes time. As a result I had to wait until November 2010 to get my tank.
Old 09-10-2011, 11:31 PM
larriveeman's Avatar
larriveeman
larriveeman is offline
my factory tank is 36 gallons
Old 09-10-2011, 11:35 PM
iggy2's Avatar
iggy2
iggy2 is offline
Actually it is 35 gal but you must have filled the pipe also.
Old 09-11-2011, 05:41 AM
2000silverbullet
Yep, you're correct, my bad. No wonder why they're so popular in the 6.7 forum.
Old 09-11-2011, 12:56 PM
RZAR's Avatar
RZAR
RZAR is offline
I got excited when I saw Transfer Flow made tank for gas trucks. The only problem is they only make them for crew cab short beds. I have a regular cab. Hopefully one day they will make one for my truck.
Old 10-10-2011, 07:34 PM
azgard's Avatar
azgard
azgard is offline
I've been eyeing tanks for a while now, everything seems to be either diesel, or made for scab's and screw's wheres the love for us guys with regular cab's?
Old 10-24-2011, 05:48 AM
KSCRUDE's Avatar
KSCRUDE
KSCRUDE is offline
My 05 reg cab F250 LB has a 38 gallon tank from the factory. Not bad with the 5.4 V8. On the other hand my 08 F350 screw SB V10 only has a 30 gallon tank which is on the small side to tow with. I have a 12 F150 FX4 on order with a ecoboost and the 36 gallon tank. 20+ MPG and 36 gallons = long range runner.
Old 11-12-2012, 06:02 PM
wee haul's Avatar
wee haul
wee haul is offline
EcoBoost mileage
Delayed response to KSCRUDE: new to forum and I'd be interested in how your 2012 FX4 is doing with EB engine and 36 gal tank. Was pleased with mine until towing 4500 lb trailer which dropped my mpg to below 10 from 21 when clean. I am searching for an auxilliary fuel tank or a fiberglass
RV trailer.
Old 11-12-2012, 09:19 PM
KSCRUDE's Avatar
KSCRUDE
KSCRUDE is offline
The dealer ordered the FX4 and forgot some of the options I wanted so I did not buy. We did order and buy a 12 expedition with the 5.4. Runs like a dog compared to the 3.5 eco! I have driven several. Everybody I know that has one says they really suck the gas towing or running at high speeds. We did buy a baby eco in a 13 escape and it runs like a scared rabbit. It say 30 highway and 25 city. Best we have ever gotten was 23 highway. Also bought a 13 Newmar 33 foot class A motor home on a ford F53 chassis. It has the V10 with the five speed auto and it makes six to eight pulling the escape on a tandem axle trailer. About 25 K total weight. It could use a 5.0 Ecoboost, not really worried about the gas, but the power would be nice.
Old 11-12-2012, 09:44 PM
wee haul's Avatar
wee haul
wee haul is offline
Thanks
Appreciate the update. My F-150 with EB 3.5L is a 2011 with only 26 gal tank, so I'm investigating a larger aux tank or newer truck. Will know in a few days.
Old 12-29-2012, 06:09 AM
bikerman2299's Avatar
bikerman2299
bikerman2299 is offline
Bump.... I am looking for a larger capacity tank for my '11 extended cab, gas, SWB, 4x4, without loosing my spare tire. Anyone?
Old 12-29-2012, 08:19 AM
KSCRUDE's Avatar
KSCRUDE
KSCRUDE is offline
Maybe you could find a newer ford in a junk yard and rob the 36 gallon tank from it. Probably pretty scarce right now though. I haven't found much line for the F150. Most fit the super duty line. Are you could maybe buy the new 36 gallon from ford and retro fit it to your rig. Probably pretty pricey though.
Dallas2142
08-07-2018 06:27 AM
dnewton3
6.2L V8
17
11-23-2017 09:39 AM
Bigdawg5565
09-25-2015 04:05 PM
dbh100
1999 to 2016 Super Duty
08-20-2013 08:14 PM
F450OldGuy
07-27-2009 07:17 AM
Quick Reply: Upgrade Fuel tank to larger capacity
