2000 Expedition AC Compressor/Clutch Noise - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 09-10-2011, 07:30 PM
spwilliams spwilliams is offline
spwilliams is starting off with a positive reputation.
My 2000 Expedition AC is making a constant noise that sounds like worn bearings. The noise occurs whether the AC is on (clutch engaged) or not. Would this point to a problem with the clutch assembly or is it the compressor going out?
Old 09-10-2011, 07:36 PM
Boat Tug Boat Tug is offline
Boat Tug is gaining momentum as a positive member of FTE.
Have you checked your Idler & Tensioner Pulley, the bearings could be making the noise.
Old 09-10-2011, 09:50 PM
I removed the belt and checked both the idler & tension pulley. Both are good. I hand turned the wheel on the clutch assembly and can definitely hear the noise. So does this mean it's just the clutch assembly or could it be the entire compressor?
Old 09-11-2011, 03:15 AM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Quote:
It is most likely only the clutch.
Old 09-11-2011, 04:57 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Fortunately I think you can get off cheap with just a clutch kit instead of a whole compressor and R134-a change. Here's a kit that's fairly inexpensive: Expedition/Navigator A/C Compressor Clutch Kit CL 0542C | eBay
Old 09-11-2011, 11:49 PM
LeeLeadingham LeeLeadingham is offline
LeeLeadingham is starting off with a positive reputation.
It's the hub more than likely on your a/c compressor.. I would recommend replacing the clutch/pulley ***'y while you can.
I had the noise, for a month, and it finally locked up on me. Costed me more than it would have if I replaced the clutch/pulley ***'y in the beginning.. Check out my thread.
Title is "Maybe you guys can help me"
AC compressor should turn freely? Blockfort Cooling, Heating, Ventilation & A/C 6 08-30-2016 01:07 AM
Help please!!! Zacks Modular V8 (4.6L, 5.4L) 1 02-07-2015 12:22 PM
Hissing noise under hood, Bad AC compressor?? HELP! Robby Nash 1999 to 2016 Super Duty 0 12-18-2012 02:33 PM
92 F250 A/C compressor clicking noise tomluoma Cooling, Heating, Ventilation & A/C 0 09-04-2012 04:25 PM
AC Compressor Clutch failure questions gitane59 1999 to 2016 Super Duty 5 07-31-2008 07:53 PM
Tags
2000, 2005, 99, ac, cheap, clutch, compressor, escape, expedition, f150, ford, idle, makes, making, noise, noises, noisy, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
