before i rip this tank out...
my rear gas tank is leaking pretty bad. also, the gas from my front tank leaks into my back tank while im driving. i have come to the conclusion that i need a new rear tank and fuel pump. will this tank setup work?
More Information for SPECTRA PREMIUM F1G1FA
it seems to have everything i will need. anything i should lookout for when i do this? will i need those weird plastic things to remove fuel lines?
Also eliminates the issue of putting the pump into the tank, THEN having a leaking tank....
Mine leaked like a ****....Changed the side tank out with the one from my 1994 truck....Same persistant leak....On the main bottom of the O-Hole where the pump rests....Now I honestly believe its the pump....
The tank that was on previously was toast....The metal tabs/ears were all FUBAR'ed....You could literally twist the sending unit around ***** nilly....
Now its nice and firm...No movemement....Just a small leak....
the pump is a 'Zone one.....So I'm thinking the mounting plate has a SLIGHT bend/crease in it...Allowing gas to still come out..
