1987-1996 F150 and Larger Curb weights?
09-10-2011, 01:10 PM
on
I just got my truck and was wondering what the weight was I read on edmunds specs that it was around 4400 but I don't believe them I might have to weight them next week lol. Anyone know their's ?
09-10-2011, 01:16 PM
I think the DMV said mine was 6,700 with a full tank of fuel.
09-10-2011, 01:27 PM
Weighing is the ONLY way to know for sure, the spec sheets you see are just darn good guesses, it varies with so called identical trucks.
09-10-2011, 01:39 PM
on
Quote:
Originally Posted by
dizzyfingers03
Interesting
09-10-2011, 05:17 PM
on
dizzyfingers03
Someone is confusing Curb Weight with GVWR. Of course GVWR is not even that high.
Edit: Just realized your truck in your sig is F250. GVWR would be about 8800lbs and Curb Weight with a Diesel would be about 6000.
09-10-2011, 08:05 PM
1987F250460
The only truck that light is a 2wd reg cab F150 everything else is heavier. My extended cab 4x4 is just a hair under 5000lbs on the local dump scales.
09-10-2011, 08:56 PM
My 96' 351W 4x4 ext cab short bed with E4OD weighed in at 5240 at the recycling center, me not in it, both tanks at about 1/4. There was probably about 80 pounds of random stuff inside it.
09-13-2011, 05:56 PM
on
I found a Ford Spec sheet that my truck 96 150 302 auto shortbed regular cab Curb is 3,850 can't remember were the hell i found it, lol let me do a search
09-13-2011, 06:05 PM
on
09-13-2011, 06:35 PM
The 3,900 is probably a striped 6 cly ?? The lightnings with the 351 were 4,400....
09-13-2011, 06:37 PM
on
lew52
I know but also the frame was thicker and had the big E40D, what i need to do is get off my but and go to a weight station
09-13-2011, 06:48 PM
Yeah , i think you will be around 4100-4200 i don't remember if you have a rear bumper or roll pan ??
09-13-2011, 06:53 PM
on
lew52
Short bed regular cab 302 4R70W, Lightning tube (40lb) bumper, Yeah i figure just under 4k or just over 4k is are curb weight
09-13-2011, 07:03 PM
Let us know when you weigh it , remember the amount of fuel and your weight if your in the truck or on the scale ....
09-13-2011, 10:48 PM
My truck on my scale at work weighs 4420 no gas no driver its 93 single cab short bed e40d 300 loaded 4x4
