General Automotive Discussion
PRNDL pointer adjustment or repair
Old 09-10-2011, 12:23 PM
shorebird's Avatar
shorebird
shorebird is offline
This is on my F-650 but is the same for all of the column shift vehicles that I know of.
Here is the adjustment wheel for the PRNDL indicator pointer.
It is located directly under the column.
The white bracket can break and the pointer will not align with the letters on the dash.
With the vehicle not running shift the column lever to L(Low).
Now you can disconnect the thin (red) cable (that moves the pointer) end loop, from the lever.
Then dismount the bracket from the column.
The bracket can be removed by rotating the wheel until the cable tube is free of the wheel.
Slide the cable out of the bracket and wheel.
Replace or repair the bracket.
Reinstall the bracket and cable.
Turn the wheel until the pointer is aligned with the appropriate letter to match the shift levers position.
Note; the least tension is on the cable when the shifter is in Low.
I then used a couple of zip ties to cinch up the bracket.
[IMG]<table style="width:auto;"><tbody><tr><td></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Drop Box</td></tr></tbody></table>[/IMG]
[IMG]<table style="width:auto;"><tbody><tr><td></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From September 10, 2011</td></tr></tbody></table>[/IMG]
Old 09-14-2012, 09:30 AM
oldboots1950's Avatar
oldboots1950
oldboots1950 is offline
Shift indicator replacement
Thank you for the post. How much of the dash does one have to remove the replace the assembly?
Old 09-14-2012, 07:53 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Typically, the lower column shroud.
Old 09-20-2012, 07:51 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
joestratton1
02-16-2014 06:51 PM
badpenny
05-07-2012 02:04 AM
armstrongfordtrucks
10-04-2009 06:40 AM
wesmansr
07-20-2008 06:14 PM
mr. dave
1997 - 2003 F150
11-08-2004 08:47 AM
Quick Reply: PRNDL pointer adjustment or repair
