You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
This is on my F-650 but is the same for all of the column shift vehicles that I know of.
Here is the adjustment wheel for the PRNDL indicator pointer.
It is located directly under the column.
The white bracket can break and the pointer will not align with the letters on the dash.
With the vehicle not running shift the column lever to L(Low).
Now you can disconnect the thin (red) cable (that moves the pointer) end loop, from the lever.
Then dismount the bracket from the column.
The bracket can be removed by rotating the wheel until the cable tube is free of the wheel.
Slide the cable out of the bracket and wheel.
Replace or repair the bracket.
Reinstall the bracket and cable.
Turn the wheel until the pointer is aligned with the appropriate letter to match the shift levers position.
Note; the least tension is on the cable when the shifter is in Low.
I then used a couple of zip ties to cinch up the bracket.
[IMG]<table style="width:auto;"><tbody><tr><td></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Drop Box</td></tr></tbody></table>[/IMG]
[IMG]<table style="width:auto;"><tbody><tr><td></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From September 10, 2011</td></tr></tbody></table>[/IMG]
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
