Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 09-10-2011, 11:45 AM
Crewcab Turbo's Avatar
Crewcab Turbo Crewcab Turbo is online now
2000 Ford F-250
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
Ccv mod causing dipstick tube leak?
Did the ccv mod and my dipstick tube leaks bad, never leaked a drop before. Put the ccv back to factory and dipstick stops leaking,two days now and not a drop. Too much blow by? Anyone have this problem? What could be the problem? Thanks for the help as always!
__________________
2000 F250 Lariat
7.3, 4R100, 4x4, CC, SB, 4"lift, 315/75/16, AIS, GTP38R, Turbonetics outlet, 4" MBRP, Swamps 200/30 Hybrids, Swamps tunes, Swamps HI V/F IDM, IH bellows, Plenum inserts, Ic boots, OCR, HPx, FRx, Hutch/Harpoon, spin on prepump filter, Bosch pump, DIY 3/8 fuel lines to heads, Autometer boost, trans, pyro, coolant, Isspro EV2 fuel press, ELC, coolant filter, BTS vb, 6.0 trans cooler, Melling LPOP, traction bars, AE and more.
  #2 (permalink)
Old 09-10-2011, 12:03 PM
bulla's Avatar
bulla bulla is offline
Garage is empty, add now
bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.bulla has a very good reputation on FTE.
Could be that the ccv in the intake causes a vacuum or at least less pressure in the bottom end and doesn't let the leak show. But If it is leaking it's only time before it starts leaking all the time!
  #3 (permalink)
Old 09-10-2011, 12:35 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
Make sure there is NO restriction in your CCV mod. It needs to be wide open!
  #4 (permalink)
Old 09-10-2011, 12:52 PM
2000 Ford F-250
I would like to try making a 3" canister out of PVC and putting filter material in it and routing it back to the original spot on the intake to see if that works better.
__________________
2000 F250 Lariat
  #5 (permalink)
Old 09-10-2011, 01:29 PM
Justin03PSD's Avatar
Justin03PSD Justin03PSD is offline
2003 Ford F-250
Justin03PSD is gaining momentum as a positive member of FTE.
Quote:
A catch can is a great idea.
I like having suction on the crankcase compared with letting the pressure build up to push it out a CCV to atmosphere.
__________________
2003 F-250 XLT 7.3 crew cab 4x4
Zoodad - 6637 covered by Pete - RiffRaff AIH delete, boots, and plenum inserts - Magnaflow #17979 4" exhaust - DP Tuner F5 chip 40T, 80E, 120R - Autometer #3804 boost and #3845 EGT gauges - EBPV delete - USA ported shroud compressor housing - Garrett high flow outlet - Warn 11690 hubs
  #6 (permalink)
Old 09-10-2011, 02:20 PM
hotroddsl's Avatar
hotroddsl hotroddsl is offline
2002 Ford F-250
My Garage
hotroddsl has a very good reputation on FTE.hotroddsl has a very good reputation on FTE.hotroddsl has a very good reputation on FTE.
Quote:
X2 X3 X4 any restriction will let pressure build up in the crankcase!
Jim & fat Monty
__________________
"I'm Jim and I'm a modaholic"PAA#111 '02 CC lariat, 4x4 6" 37x12.5 70R17 BAJA TA's, JW trans, 7.3, AFE intake, blade runner, AFE 5" exh., GTP38R non-wastegated, Beans stage II, Mahle ceramics, crower rods, 6.0 spearco CAC, Adrenaline HPOP, ceramic manifolds, TS Performance by BDP and yes, it's FAST!;'07 4x4 DRW CC Lariat moonroof & leather, 6", 6.0L PSD, 4" AFE, CAC & high ram, tuning by spartan, '07 Warrior 39 CR. '98 &'99 Expey's, custom rack by Dr. Fam
  #7 (permalink)
Old 09-10-2011, 04:08 PM
cleatus12r cleatus12r is offline
cleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud ofcleatus12r has much to be proud of
Quote:
DING! DING! DING!
We have a WINNNNAAAAAHHHHHH!
Low pressure crankcase ventilation systems are the cat's meow. It's the only good EPA-mandated emission control system that actually has a purpose and helps.
Would you disable the PCV system on your gasoline-powered car? I didn't think so.
__________________
  #8 (permalink)
Old 09-10-2011, 04:39 PM
CSIPSD's Avatar
500k with an open CCV without one issue...
IH versions are open CCV...
The issue is not an open CCV, its with people having restrictions in the CCV.
  #9 (permalink)
Old 09-10-2011, 04:44 PM
2000 Ford F-250
How long of a hose is ok? Mine I have running back to above the rear axle cus I hate the smell.
__________________
2000 F250 Lariat
  #10 (permalink)
Old 09-10-2011, 06:52 PM
hotroddsl's Avatar
2002 Ford F-250
My Garage
I leave mine in place as I would rather have negative or close to it pressure it the cranckcase as I believe this Leads to a lower ash content in my oil over time however I have no data to prove it just a gut feeling based on a common sense approach to less blowby smoke to interact with oil surface will lead to less oil contamination! I could be entirely full of s..t on this but it just seems right to me.
Jim & fat Monty
__________________
  #11 (permalink)
Old 09-10-2011, 09:12 PM
bulla's Avatar
International manufactured the motor and originally vented it to atmosphere. Ford changed it to clean it up a bit. As always this is a debate but either way is probably just fine! By the way your not the only one with the hose ran all the way to the back of the truck. With being routed into the intake I wouldn't think it would puff when the fill cap is removed, but more less just gives it a contained area to go to.
  #12 (permalink)
Old 09-10-2011, 09:14 PM
bulla's Avatar
Either way you should probably look into changing the o ring on the dipstick fitting thing a ma jig!
  #13 (permalink)
Old 09-10-2011, 09:40 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
1999 Ford F-250
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
I got a leak at the dipstick tube right after doing the CCV mod. I found out it was the dipstick tube o-ring (not the flange o-ring in the pan). Pulled the dipstick tube out of the flange and the o-ring was gone. Replaced o-ring and have had no leak going on 3 years.
Dipstick Tube O-ring at Dieselorings
  #14 (permalink)
Old 09-10-2011, 10:04 PM
gradyc's Avatar
gradyc gradyc is offline
wellhead
gradyc is starting off with a positive reputation.
Crewcab, I purchased a catch can at Tractor supply, around 10 bucks. Works great.
My hose only runs to the back of my cab.
I know a lot of you keep saying the the CCV has a very obnoxious odor. With my truck I don't find that to be the case. I had changed to Rotella Syn. before I did the CCv mod. Not sure if this has any effect on the odor.
__________________
-Grady-
2001 SD F250 XLT SUPER CAB 4X2 SB 7.3 PSD
4R100 Tranny (no diode )
Mods - zoodad-Isspro EV2 gauges,boost,pyro, tranny-6637 with cover-in tank mod-gpr led-AIH delete--CCV mod- four bit mod-2" front levelling blocks-6.0 IC and tranny cooler-RiffRaff plenium inserts & IC boots-DP Tuner-Bilstein 5100's.
  #15 (permalink)
Old 09-10-2011, 10:35 PM
joeyd61's Avatar
joeyd61 joeyd61 is online now
2003 Ford F-250
joeyd61 has a very good reputation on FTE.joeyd61 has a very good reputation on FTE.joeyd61 has a very good reputation on FTE.
I dont think the length matters...you can not have any high spots because oil will build up and cause problems in the low spot.....I actually ran a piece of PVC tubing inside of my frame and dump just behind the back door.....
__________________
Joey PAA 115
2003 F250 LARIAT 7.3PSD,RHN Member,Fresh Forged Rod Motor,BTS trans,6.0 Trans cooler,DP F6 Tuner LIVE TUNED ,Full Force stage 3 Hybrid injectors,BW S468 Turbo w/T4 mount,Terminator DUAL HPOP,AFE Stage 2 XP Pro 5R Intake,ISSPRO ev2 Guages,AirDog 150 w/sump,Walbro fuel pump,SD Regulated Return,CCV,4.56 Yukon gears,6" BDS lift,37" Toyo tires,Armed with Infinity,and on and on...
Tags
2000, 64, 73l, aftermarket, ccv, enthusiasts, f250, ford, fr, great, hose, lights, mod, shemale, truck, tubes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
