Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 09-10-2011, 09:38 AM
ROBARTS ROBARTS is offline
Garage is empty, add now
ROBARTS is starting off with a positive reputation.
shawn robarts
Question Aussie 76 F250 4x4
Hey lads, new to the site great read very helpful this is the reason i started to look a bit harder into the 76 F250 LWB 4x4 i picked up a year ago.
I was looking for a 77 f100 4x4 LWB at the time but came across this F250 4x4 the add read "76 f250 4x4 460ci auto stally shift kit disc break front and power steering Canadian truck with rare steel dash"
Fingers crossed and with alot of help and reading on this site i might have a better truck then i bargained for
So far iv worked out the following from you blokes:
The 460 must not be the original engine of the truck should be a 390 i believe?.
It has a C6 auto, divorced 205 TC.
Dana 44HD 1710HD front open knuckle low pinion with 79mdl front disc brakes and Power Ram Assist steering.
Dana 60 FF rear axle but i looked up the B.O.M and it told me its a 79mdl 4x2 axle so bit puzzled there? but you can see where U bolts were mounted previously and sit quite wider then bolted to this truck.
Fuel tank is in the cab.
Chassis rails run straight with cross member at front.
Things i cant work out:
Steel dash and cluster what models came with this and why do they differ between trucks?
Rear axle ratio is 4.10 but the front axle is 4.09 im tipping this is from the rear diff swap but how will this different ratio's affect the transfer case?
Cant find original Vin it has a police Vin: V942624P?
Measure from out side to outside chassis rail rear is 34.05" 865mm cant find these dimensions?
Is it a "Highboy"? dont want to say it is before i have some concrete because i laugh at the bloke's that claim they have these ridgy didge trucks but really dont have a clue!
All in all info about when this model came to Oz what models came and what this Steel Dash could mean? looks trick happy with it!
Cheers lads once i work out how to put pics up you might get a better idea.
  #2 (permalink)
Old 09-10-2011, 07:27 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
G'day M8 and welcome to FTE. Have you looked in this forum
1973 - 1979 F-100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Scroll down. highboy's thread on he's 76 Highboy has heaps of pics. Might want to have a yarn to him
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
Tags
4x4, 76, disc, f250, forums, front
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
