REPLACED STEERING BOX, HOW DO YOU BLEED THE SYSTEM - Ford Truck Enthusiasts Forums
Old 09-09-2011, 10:26 PM
93truck 93truck is offline
93truck is starting off with a positive reputation.
I just replaced the steering box, i also have a new pump. How do i bleed the power steering . I dont have any power steering at low speeds.
Old 09-09-2011, 10:34 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Put it up on jackstands, fire up the engine and keep it at 1500 RPM or so and cycle the steering from lock to lock. The escaping air might push out some fluid but that's okay. Stop the engine, add a bit more fluid, and repeat.
Then check the fluid level while it is running and top it off to the full level.
Old 09-09-2011, 10:35 PM
supercabfreak's Avatar
supercabfreak supercabfreak is offline
supercabfreak is starting off with a positive reputation.
after i changed my box i had the front end up on the lift i filled the pump and let the engine idle and ran the wheels stop to stop quite a few times til i didnt have to add any oil ..........idk if thats the wat your suposed to or not but thats what i did and it worked
Old 09-10-2011, 12:47 AM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
thats what ive always done.
Old 09-10-2011, 07:03 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Quote:
Hope the bleeding air out takes care of it. There are instances where they won't work properly at low rpm's. Didn't mention if steering box was new or used. If used, a good flushing wouldn't hurt.
Old 09-10-2011, 09:02 AM
is it the correct pulley for the motor? they dont all use the same diameter pulley.
Old 09-10-2011, 10:18 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Wasn't there instructions with it ? You NEVER EVER run the engine while bleeding the system. Thats how new parts can get damaged. You want your fluid (calm) while bleeding the system.
Old 09-10-2011, 11:58 AM
HIO Silver's Avatar
Quote:
Disagree.
You NEVER EVER run the PS pump without first filling up the system. The term "bleeding" assumes it HAS fluid.
Old 09-10-2011, 05:07 PM
It was a used unit. Replaced the pump a while back. Its noisy now and having a hard time at low idle. Maybe I will flush it out and start over. If not. I will get another gear box since it was quiet before I started
Old 09-10-2011, 08:55 PM
79superduty 79superduty is offline
79superduty is starting off with a positive reputation.
YOU DONT HAVE TO FLUSH IF YOU DONT WANT TO.. TURNING THE WHEEL WONT MAKE IT FILL ANY SOONER EITHER. THE BEST THING IS TO FILL TO THE BOTTOM OF THE TUBE AND LET IDLE, AIR WILL COME TO THE TOP AND IT WILL SOON FILL.. JUST BE PATIENT....
Old 09-05-2013, 01:33 PM
jon nichols jon nichols is offline
jon nichols is starting off with a positive reputation.
power steering issue
i was hot roding my f250 4x4 and lost all power steering so i replaced the pump and now the steering is like its got a high low spot has power then it doesnt.
what could cause this i didnt hit anything i was just in 2 wheel drive going up hill is this an air issue HELP
Old 09-05-2013, 01:36 PM
POWER STEERING ISSUE
BY THE WAY ITS A 79
Old 09-05-2013, 04:47 PM
84espy 84espy is offline
84espy has a good reputation on FTE.84espy has a good reputation on FTE.
Removing the tires before firing up the engine will give a more complete bleed as it will allow the steering to go max side to side
Old 09-05-2013, 05:04 PM
maverick600's Avatar
maverick600 maverick600 is offline
maverick600 is starting off with a positive reputation.
For whats its worth I had the same problem with mine. I had replaced my pump with a reman and at idle or coming in to a tight curve or stop sign I had no power steering. I could pop the hood and watch the return hose jump when i revved up the engine. I tried all the ideas of bleeding the system and come to find out I just had a bad pump.
Old 09-05-2013, 07:37 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
My bet .... Bad Pump.
Lost Power steering and brakes Big Air 1999 to 2016 Super Duty 3 09-11-2016 10:45 AM
2000 ford f150 power steering goarmy56 1997 - 2003 F150 1 08-06-2016 10:23 PM
Power steering bleed trouble Bigjay74 1999 - 2003 7.3L Power Stroke Diesel 3 03-22-2016 09:26 PM
Bleeding Air From Power Steering brenthottle 1999 to 2016 Super Duty 22 07-09-2014 12:22 PM
Garrison Control Valve hose configuration 74F2504by4 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-26-2012 09:18 PM
Tags
150, 1994, 1997, 2003, 2005, bleed, bleeding, box, diesel, explorer, f150, ford, power, steering, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
