92 getting Power but No Spark
I got a 1992, 4.9 engine. I run the diagnostic tests and am getting power to the coil but no spark out of the coil. I changed out the coil and get the same results. This really has me scratching my head...Distributor Cap and button are less than a year old. Tried a new pick up coil and Module...still no luck. If anyone has a clue "PLEASE" let me know.
Hmm, I have a suggestion. If there is power to the coil it should spark. So, Does anyone think his ignition switch could be bad causing no power to the coil while in the key is in "Start" position??? A good way to try this is turn the key to "On" and jump the starter relay to see if it starts. If it does start, It's something with the ignition switch or something. Just a thought because if you have power, your coil SHOULD spark. That's what confused me..
Good luck!
*Oh one more thing. If it's a manual trans, make sure it's in neutral and someone is pushing the clutch in. Jumping the Starter Relay bypasses ALL safety switches*
Do you have a tachometer in the truck? If you do, does it show any RPM reading when cranking the truck? If you do not have a tach attach a meter or test light to the coil. Have someone crank the engine, does the test light blink or if using a meter does it display any voltage? Should be in the 3 to 6 volt range.
If any of those fail it could be a wiring problem. You mentioned before you replaced the PIP and TFI. So unless you got another bad one straight out of the box it is looking like a connector or wiring problem.
Another test to try is momentarily ground the negative side of the coil, see if you have spark. If you do then the problem is on the negative (trigger) side. If not perhaps that supply voltage you measured is really stray/phantom voltage from an open circuit.
badasssapper67
08-06-2015 02:43 PM
Schwinn240
07-17-2009 08:06 AM
Bassfever1
Electrical Systems/Wiring
05-21-2004 09:23 PM
