Sway Control?
Old 09-09-2011, 07:51 PM
eaglebqh's Avatar
eaglebqh
eaglebqh is offline
Sway Control?
Does the Ford "Sway" Control replace the need for a Weight Distribution Hitch for pulling a 6000# trailer?
Old 09-10-2011, 03:00 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
On a calm (no wind) day with light traffic on a straight road with an aerodynamic trailer that's properly loaded? Yes.
Any other situation...Kind of.
Never hurts to have belts and suspenders.
Old 09-10-2011, 07:35 AM
eaglebqh's Avatar
eaglebqh
eaglebqh is offline
Thnx shotgunz ... kinda what I thought too. Seemed to replace a little bit of the functionality but not all.
Old 09-10-2011, 09:24 AM
flixden's Avatar
flixden
flixden is offline
I'd still want a WDH.
The sway control that is built in does not do any weight distribution, right? And I think you really want that, at least if this is a TT with a tongue weight approaching 800, maybe up to a thousand lbs even (15% maybe of th trailer weight).
Old 09-11-2011, 10:43 PM
jimmyb08SD's Avatar
jimmyb08SD
jimmyb08SD is offline
No it does not do any weight distribution, and you should not use it to replace a good sway control system! It should only be used to compliment a good sway system, not replace it. Suggesting other wise is bad advice!
Old 09-12-2011, 08:37 PM
cub129's Avatar
cub129
cub129 is offline
2X JimmyB comments
You should not rely of the onboard sway control for anything other than extra help in a REALLY BAD situation. It does not replace a good weight distributing/sway control hitch like an Equal-I-Zer or Reese roller cam. I tow a 7500# Travel trailer with my '09 SCrew 4x2 5.4L3V with Ride Rite air bags and an Equal-I-Zer and don't feel like it's over equipped by any means. It isn't worth barrel rolling down the highway on a family vacation!!!
Curt's05
Toy Hauler Towing; Fifth Wheel & Bumper Pull
06-27-2019 09:13 PM
calivw78
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
11-01-2017 09:27 AM
mattnj
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
11-28-2016 10:36 PM
Beaglebus
08-09-2010 05:06 PM
damone
03-26-2004 04:53 AM
Quick Reply: Sway Control?
