Very slow low idle when warmed up
Hard to know if there is a loss of power because it has been this way as long as I have owned it (a few weeks). It does not seem to be struggling though so probably no loss of power.
It's not just a low idle, at speed I can feel the engine is erratic as if I'm moving the throttle in and out a tiny bit.
TwoMuchMud , did you find a solution to your problem?
It has gotten a lot worse the last few weeks. Very rough low idle that shakes the whole truck. A new symptom is sometimes a very high idle/running speed of 3k RPM or so. Vacuum lines still seem fine, IAC or TPS are the only other things I can think of that could cause this. The TPS tests fine so that leaves the IAC.
I'm fairly convinced it's the IAC but I have never figured out how to get to that stupid thing. It seems 100% impossible without removing the whole intake manifold.
wilevel2
07-07-2009 04:24 PM
