Very slow low idle when warmed up - Page 2 - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 09-30-2011, 06:47 PM
TwoMuchMud TwoMuchMud is offline
TwoMuchMud is starting off with a positive reputation.
Hard to know if there is a loss of power because it has been this way as long as I have owned it (a few weeks). It does not seem to be struggling though so probably no loss of power.
It's not just a low idle, at speed I can feel the engine is erratic as if I'm moving the throttle in and out a tiny bit.
Old 06-28-2014, 09:18 PM
WB4IUY WB4IUY is offline
WB4IUY is starting off with a positive reputation.
TwoMuchMud , did you find a solution to your problem?
Old 07-30-2016, 08:10 AM
bentmetal bentmetal is offline
bentmetal is starting off with a positive reputation.
Quote:
Sorry, I lost my account details for the other account but I never did fix this.
It has gotten a lot worse the last few weeks. Very rough low idle that shakes the whole truck. A new symptom is sometimes a very high idle/running speed of 3k RPM or so. Vacuum lines still seem fine, IAC or TPS are the only other things I can think of that could cause this. The TPS tests fine so that leaves the IAC.
I'm fairly convinced it's the IAC but I have never figured out how to get to that stupid thing. It seems 100% impossible without removing the whole intake manifold.
1990 460 idle down issues 8ACHEBBY Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 02-23-2017 09:07 AM
Aftermarket TPS question... DSN46 Excursion - King of SUVs 2 11-20-2013 11:25 PM
1999 4.0L stalls, rough idle, engine dies tlk401 Ranger & B-Series 16 04-20-2013 12:50 AM
Low RPM Surge When Cold SteevenH 1997 - 2003 F150 4 09-15-2010 09:41 AM
Engine surges under load, 'sticky' high idle daring Explorer, Sport Trac, Mountaineer & Aviator 21 11-21-2009 09:51 PM
Tags
2004, air, bronco, control, dies, escape, ford, idle, idles, ii, low, rpm, taurus, valve, warmed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
