Equus 3145 reader
Equus 3145 reader
I picked up an Equus reader after my last round of my TPS needing replacement. I thought I'd run through and check with the reader to see if anything showed up with the engine running codes. Nothing showed up BUT.... The reader showed a 6 instead of an an 8 as to the cylinders. I have the 302. Has anyone run into this? I'm thinking if there were any codes, then if it was thinking I had a 6 cylinder, then something might or might not show up because of this and possibly be an incorrect code.
maybe i should have clarified, I meant multilingual as in the display, and is your equus unit the same as innova (same company/brand)? my bad if i confused you man! I read the equus units have spanish interface (capability), i dont know if they talk persay but im looking into snatching one of these units as I feel more comfortable using them...can you connect yours to a PC using a USB cable? if so then im sold on the equus/innova units!!
link to what im looking at so your clear on what im talking about
http://cgi.ebay.com/ebaymotors/Innov...item5193bc98a8
as for the reader seeing your truck as a 6 instead of 8 cylinders I would suggest going to the local store you got it from (or maybe another store you know has a similar unit like vatozone just to test) and having them grab another unit that can do essentially the same things and see if it reads the same, if it does then its isolated to the ECU, if it doesn't read the same or it gives you different results then it would most likely be the reader having an...identity crisis....with its self....
Madmike33
1983 - 2012 Ranger & B-Series
02-20-2007 11:56 PM
