Traditional lift kit feedback
Looking to lift my '88 f250 (in the process of installing a d60 also) and just want some feedback on regular lifts (not the rsk lifts).
Anyone still running reg lifts on their f350s (that's what this will be when I'm done). What lift do you recommend? How's the ride and quality of the lift components?
Ride quality as good or a little better than stock suits me fine.
The super lift spring were much more heavy duty, definitely not as smooth of a ride but sat where it should be
From what I've been told, a lot of companies will list the same springs as 6" for gas, and 4" for diesel because of the extra weight. Something to keep in mind.
Shouldn't take much when you get that 60 in. I'm running 37's on stock suspension until I get around to building a junkyard shackle reversal. 35's you'll have no problem with using at least the flat 350 springs.
sub'd. I may be using SD springs when i do the D60 swap on th 92. From what i understand there is a bolt in RSK kit fur use with the SD sprins, cant remember what thread it was talked about though. Im must looking for a solid axle however, dont really need even the lift that will give me let alone an RSK
I have superduty springs in the front, and rear too.
Home made RSK, originally had gas 250 front springs and the ride sucked *****. Re-did the RSK to move the front mount forward for the superduty springs and it rides hell of a lot better now.
The 250 gas springs were pretty beat when I put them in. And completely flat when I took them out. While moving the front mount forward, I also moved it up a couple inches. Even then I got about another inch from the superduty springs. Unlike all the rest of you, I was trying to avoid lifting the front any more than I had putting the D60 in there. As it is, I'm trying to figure out a way to lower the rear by reworking the shackles and not sure I can get it to work.
I dont want lift. I actually kinda like how it sits now, but the TTB sucks for being out here in the rocks/mud/snow clearance wise, and rides like a tank. Just the D60 swap itself gives around 2 inches, which i think will be perfect for a set of 285s. Guy i work with has a stock 90 F350 and clears 35s no problem.
