That other new guy
Old 01-09-2012, 03:28 PM
old_dan's Avatar
old_dan
old_dan is offline
I'm pretty sure that they are plain old 5/16 bolts....with fine threads (so 5/16-24 UNF). A lot of the body parts on these trucks was bolted together with 5/16 fine thread bolts....there are a few places with 3/8" bolts...like the bolts that hold the inner fender to the radiator support...those are also fine thread bolts.
  #47
Old 01-09-2012, 03:34 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
I can look it up when I get home this evening.
  #48
kbusby's Avatar
kbusby
kbusby is offline
I was actually talking about the large bolt that fits through spring...
  #49
Old 01-09-2012, 04:20 PM
kbusby's Avatar
kbusby
kbusby is offline
Thanks I had sent an email. Looks like getting it threaded would cost more then buying one..
  #50
Old 01-09-2012, 11:32 PM
51PanelMan's Avatar
51PanelMan
Just as I suspected, and remembered, the bolt is of special construction. It has a mushroom tip at the bottom in order to engage the hood latch.
As per the parts manual (see pictures below), it's part # 1C-16929 and is 3.66" long. The 48-50 uses the same bolt, but it's 5" long and has a part # 7C-16929. The 48-50 also utilizes a separate 7/16"-20 nut. The nut on a 51-52 hood assembly is welded to the hood. I would assume that it's also a 7/16"-20 thread.
I doubt that you'll find this special bolt at your local hardware or auto parts store. If you're set on finding an original, then I suggest trying Green Sales Co in Ohio and/or Antique Auto Supply in Arlington, TX. Otherwise, I'd spend the money and have the existing bolt re-threaded to the correct specs.
  #51
Old 01-10-2012, 12:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
They really aren't that different from dozens of other vehicles that use that kind of latch. The head on mine measures 1-1/8" diameter at the widest part, and the bolt needs to stick down from the underside of the hood at least 2-1/4", so is probably a 3" overeall length. It's useless without the spring and cup to match tho, so grab them too.
  #52
Old 01-10-2012, 01:16 PM
kbusby's Avatar
kbusby
kbusby is offline
Have the assembly just have a messed up bolt that needs re threaded but thought I might could find for less than the machine shop wants for re threading this one.
  #53
Old 01-10-2012, 01:33 PM
51PanelMan's Avatar
51PanelMan
How much are they charging? It's probably less than the time it would cost you to find one. Check the thread inside the nut. Maybe it's bad as well.
  #54
Old 01-10-2012, 06:10 PM
kbusby's Avatar
kbusby
kbusby is offline
47 an hour but a friend called and had a die for it.. So I will do it this weekend.
  #55
Old 01-11-2012, 10:14 AM
kbusby's Avatar
kbusby
kbusby is offline
Window channel
Can anyone measure the distance from edge of window to edge of lift channel? Trying to get it in but having issues with the alignment. Thanks
Ken
djb2520
21
05-05-2011 09:25 PM
Cody_1948
15
03-15-2011 09:46 PM
gdgerland
29
09-14-2007 02:36 PM
harley89
11-09-2003 12:37 AM
Orsk
13
06-26-2003 11:00 PM
Quick Reply: That other new guy
