Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-08-2011, 08:54 PM
joeflexromine joeflexromine is offline
Garage is empty, add now
joeflexromine is starting off with a positive reputation.
1.9 turbo problems
I have a 1.9 motor and i put a turbo on it. the motor has diamond pistons and crowder rod its all build to hold over 20 lb of boost it has a MSD boxs, crank trigger, innercooler and a FAST computer. the motors has been tuned on a dyno and has been running great until now
the problem
when reving up the motor when it hits 5000 RPMS it drops the RPMS back down to about 3000 even when floored.. I replaced the crank trigger sencer and the TPS what esle could it be ??
  #2 (permalink)
Old 09-09-2011, 11:06 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Does that MSD box have a rev limiter built in? Kinda sounds like it's hitting the rev limiter...
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 09-09-2011, 11:10 AM
Ya it does I put a new chip in it and still the samething it really doesn't drop like a rev limiter its like it just looses spark or gas u think it could be a bad msd
  #4 (permalink)
Old 09-09-2011, 11:35 AM
TigerDan's Avatar
1968 Ford F-250
I suppose that's possible. Never run an MSD so I'm not very familiar with them...does it have a way to bypass it so you can run without it if it takes a dump on you?
__________________
  #5 (permalink)
Old 09-09-2011, 01:14 PM
No without it theres no spark I'm thinking the msd is going bad or something to do with fuel
  #6 (permalink)
Old 09-30-2011, 10:07 PM
SixGunCaliforniaKid's Avatar
SixGunCaliforniaKid SixGunCaliforniaKid is offline
SixGunCaliforniaKid is starting off with a positive reputation.
DaBoomhower
which MSD box are you using? the sport compact? if its the one with selectable cylinder (4,6,8) check your switch. if your using more than one box thats no bueno... if it has anything to do with the MSD its usually the CPS thats playing with it.. have you tried the troubleshooter for the MSD?
Tags
19, box, bypass, chips, crouter, ford, make, msd, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
