Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Missouri Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Missouri Chapter Join Chapter , Leader:tcbofade
  #1 (permalink)
Old 09-08-2011, 05:55 PM
tcbofade's Avatar
tcbofade tcbofade is offline
1986 Ford F-150
tcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputationtcbofade has a superb reputation
Rubber Duckie, you're the one...
Loooong story.
Before I accepted my position at my current employer, I did some contract work for them for a year or so... As some of you may know, the extrusion process involves a requirement for a cooling agent...in this case, water. It doesn't even really have to be COLD water, just cool enough to remove heat from 350 degree plastic.
As most do, the extrusion line at work has a water trough that the newly formed wire passes through BEFORE it physically touches anything else. (Thus the wire will keep it's shape...)
Anyhow, we use two water troughs, two air wipes, and recirculate the water on the line...which requires a bath tub....which some wise guy had put a rubber ducky in.
I was so impressed with this frivolity that I took pictures of the duck floating in the bathtub.
Sometime after I became a full time employee, the aforementioned duck became stuck in the float valve that controls the water level in the bath tub...which resulted in flooding the wire mill.
The maintenance man did verily removed the duck from the bath tub at a rather high velocity.
I recovered the duck and reinstalled it in the bath tub. (Turns out that duck has seniority on BOTH of us.)
Maintenance was not pleased with my decision, but did come up with a compromise...a "leash" for the duck so that it would no longer get stuck in the float valve.
__________________
Join the Missouri Chapter!
If my Aunt had stones, she'd be my Uncle...
  #2 (permalink)
Old 09-08-2011, 05:56 PM
tcbofade's Avatar
1986 Ford F-150
Not sure if you can tell from that pic, but that "leash" bears a striking resemblance to a noose.
He hung my duck.
__________________
  #3 (permalink)
Old 09-08-2011, 05:57 PM
tcbofade's Avatar
1986 Ford F-150
While visiting a flea market/swap meet with my redheads last weekend, I found rubber duckies for 50 cents each.
I bought 20 of them and have spent this week hiding them all over the campus...not just the wire mill.
That poor maintenance man is going to be finding rubber duckies for years...
__________________
  #4 (permalink)
Old 09-08-2011, 06:12 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Workaholic
1978 Ford F-250
My Garage
77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold77&79F250 is a splendid one to behold
OMG now that is a awesome story, any pic of the hidden ducks? What will make the maint man go looking for them, typical maint duties around campus?
__________________
77&79 F250 Rich & Penny
77 351M auto, factory a/c add a leaf/33x12.50's
78 (79 headlights) 460 4 spd, factory a/c and 35's
79 351M 4spd 6" Skyjacker Edelbrock-Holley-Hedman 35's
99 Ranger 4x4 Ext Cab Flareside V-6, 98 Expedition EB 4x4
71 Bronco 302 35" Boggers 5.58 gears spool/locker
  #5 (permalink)
Old 09-08-2011, 09:49 PM
zstangkrewson's Avatar
zstangkrewson zstangkrewson is offline
Garage is empty, add now
zstangkrewson is starting off with a positive reputation.
so you make metal wire or plastic rod
I use extrusion welders to make chemical plating equipment... go to www.plastictankshop.com and see some of the stuff i worked on...
  #6 (permalink)
Old 09-08-2011, 09:53 PM
pintoches's Avatar
pintoches pintoches is offline
1979 Ford Bronco
My Garage
pintoches has a good reputation on FTE.pintoches has a good reputation on FTE.
Thats funny!
__________________
Pintoches, Ches Lathim,
79 Bronco 400, T18, D44, 9in, 37x12.50X16.5
  #7 (permalink)
Old 09-08-2011, 10:44 PM
77&79F250's Avatar
Workaholic
1978 Ford F-250
My Garage
Terry is a metal wire making expert-ologist/rubber duckie hiding fool, lol.
__________________
  #8 (permalink)
Old 09-09-2011, 04:54 PM
tcbofade's Avatar
1986 Ford F-150
Well, you're half right, Rich...I won't specify...
I make both PVC insulated bare copper wire, and silicone coated ignition wire for automobiles.
No pics of hidden duckies yet, but I can get some...
__________________
  #9 (permalink)
Old 09-09-2011, 05:03 PM
tcbofade's Avatar
1986 Ford F-150
Quote:
Ding! I started hiding them on Tuesday, and he's already found two of them. He keeps asking me how many I hid...I ain't tellin'...
__________________
  #10 (permalink)
Old 09-09-2011, 05:15 PM
77&79F250's Avatar
Workaholic
1978 Ford F-250
My Garage
Be aware this this could turn in to a one sided sharp boomerang, caught with no glove, ouch.
Buts still funny as hell.......quack quack.
__________________
  #11 (permalink)
Old 09-12-2011, 04:39 PM
tcbofade's Avatar
1986 Ford F-150
Quote:
One little ducky hidden in HAV cooling trough #1.
__________________
  #12 (permalink)
Old 09-12-2011, 04:40 PM
tcbofade's Avatar
1986 Ford F-150
One BRAVE little ducky floating out in the open on HAV cooling trough #2.
__________________
  #13 (permalink)
Old 09-12-2011, 04:42 PM
tcbofade's Avatar
1986 Ford F-150
One ducky foolishly sitting on an alarm sensor that frequently fails...
__________________
  #14 (permalink)
Old 09-12-2011, 06:13 PM
77&79F250's Avatar
Workaholic
1978 Ford F-250
My Garage
LMAO....... thanks for the pic Terry.
__________________
  #15 (permalink)
Old 11-19-2011, 10:12 PM
zhilton's Avatar
zhilton zhilton is offline
2004 Ford F-250
My Garage
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
And I thought I pulled some mean crap at work. When I first saw the second "hiden duck" photo...I thought someone had put a condom on it's head. I'm sure that says something about me...just not sure if it's good or bad.
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
Tags
bronco, duckie, rubber, trucking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
