2000 Expedition will not go into park
Found out last night that the X will not go into park. I am able to shift through all the gears but I can't bring shifter into park position. It stops somewhere between park and reverse but it is close enough to reverse that the reverse audio signal comes on and the vehicle will go backwards. When the vehicle is turned, the vehicle will roll when pushed.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
On the Excursion, there are some small torq screws that come loose and eventually fall out. They are under the driver's section up by the brake and gas pedals. Have someone move the shifter while you look around under. You should be able to find it.
Meagandub817
01-28-2019 02:36 PM
KayOliver
08-18-2017 04:03 PM
steven snow
11-15-2016 05:37 AM
