2000 Expedition will not go into park - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 09-08-2011, 11:25 AM
proudfrog's Avatar
proudfrog proudfrog is offline
proudfrog is starting off with a positive reputation.
Found out last night that the X will not go into park. I am able to shift through all the gears but I can't bring shifter into park position. It stops somewhere between park and reverse but it is close enough to reverse that the reverse audio signal comes on and the vehicle will go backwards. When the vehicle is turned, the vehicle will roll when pushed.
Any suggestions?
Old 09-08-2011, 08:59 PM
gr8scott72 gr8scott72 is offline
gr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant future
Quote:
Any suggestions?
Probably the same as an Excursion. (This IS the Excursion section, not the Expedition section.)
On the Excursion, there are some small torq screws that come loose and eventually fall out. They are under the driver's section up by the brake and gas pedals. Have someone move the shifter while you look around under. You should be able to find it.
Old 09-09-2011, 03:17 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Moving to the Expedition forum....
Old 09-09-2011, 06:27 PM
Boat Tug Boat Tug is offline
Boat Tug is gaining momentum as a positive member of FTE.
Old 09-10-2011, 09:31 AM
proudfrog's Avatar
Silly me. The problem is with my wife's Excursion, that is why it was posted in the Excursion forum. Anyways, all you advice came handy I was able to fix it!!! Now, I'm going to my Expedition and tighten those too!
2008 Ford E150 not going in reverse johnnys30 1968-2013 Full Size Vans 8 09-21-2015 09:12 PM
Reverse lights only come on between park and reverse grande1972 Ranger & B-Series 7 03-17-2013 07:21 AM
Backup Sensors Ironhide Excursion - King of SUVs 8 12-24-2012 06:01 PM
Truck won't go into park HELP!!!! cclc1021 1994.5 - 1997 7.3L Power Stroke Diesel 10 06-27-2011 09:33 PM
Grinding noise in reverse and parked on steep inclines. General Davis Aerostar 5 12-06-2002 08:26 PM
Tags
01, 1999, 2000, 99, dont, expedition, f150, ford, mot, navigator, park, reverse, shift, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
