New Gauges Installed(pics) - Ford Truck Enthusiasts Forums
Old 09-08-2011, 01:38 AM
AJHEATING AJHEATING is offline
AJHEATING is starting off with a positive reputation.
I got my new gauges so I thought I would show how I did it. I wanted new gauges all were going bad if not gone all the way. I didnt want to make a whole new dash, wanted to keep the stock dash and just put new gauges in. took a drill and drilled out all four corners in the openings. used my dremel with cut off wheel and cut from back side. used a sandpaper wheel on the dremel and smooth everything out. cut out a new back piece with holes on plazma table at work,screwed it in with original screws, threw some flat black on it. all fits pertty good. tight for two 2" gauges, but fit. just need to get it all wired back in. Got new speedo cable and 02 sensor coming. just need to figure out what wires are gas gauge though. any help what be great thanks.
Old 09-08-2011, 01:42 AM
few more pics
Old 09-08-2011, 02:26 AM
four-sixty-power's Avatar
four-sixty-power four-sixty-power is offline
four-sixty-power has a very good reputation on FTE.four-sixty-power has a very good reputation on FTE.four-sixty-power has a very good reputation on FTE.four-sixty-power has a very good reputation on FTE.
nice, simple clean, good job!
Old 09-08-2011, 02:42 AM
CueMan's 78 F-150 CueMan's 78 F-150 is offline
CueMan's 78 F-150 is starting off with a positive reputation.
I really like that! I am having issues with my gauge lights not working and this is a great looking fix to my problem as well. Would you be willing to share info on where you purchased those, part numbers, general pricing and what kind of real time it took to install? I would like to do this same thing to my 78 4x4.
Thanx,
Jim
Old 09-08-2011, 06:32 AM
i-w's Avatar
i-w i-w is offline
i-w is starting off with a positive reputation.
yes looks great! nice work. how about a night time pic with just gauge lights on.
Old 09-08-2011, 07:03 AM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
Very nice.
Old 09-08-2011, 07:49 AM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Looks great..I gotta work on that upgrade.
Old 09-08-2011, 08:26 AM
desperado_18_2000's Avatar
desperado_18_2000 desperado_18_2000 is offline
desperado_18_2000 is gaining momentum as a positive member of FTE.
Looks really clean, I dig it!
Old 09-08-2011, 08:45 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
I like the idea, but what do you do for a radio?
Old 09-08-2011, 09:32 AM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
I agree with everyone else that it looks great, but...
I used to have those gauges in my truck and after a couple of years they got to where the needles would stick and I would have to thump them to try to jar the needle loose sometimes it worked sometimes it didn't. It just got annoying driving around with 0 oil pressure and cold engine temp. LOL The volt meter still works though I actually have it mounted in my 01 Montero Sport now.
Old 09-08-2011, 11:16 AM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Nice job. Nice and clean. I really like the wonder woman edition steering wheel too. 
Old 09-08-2011, 11:57 AM
I got them all on amazon, few parts from summit. you can buy all from local autozone, but about 100.00 cheaper online. by the time done just under 300.00 installed. I have about 4 hours into it as of right now. not wired in yet. probably another 4 hours to finish and put back together. I will show picture of lights on when done.
Old 09-08-2011, 04:49 PM
cowboywanabe's Avatar
cowboywanabe cowboywanabe is offline
Posting Legend
cowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputationcowboywanabe has a superb reputation
Looks good!
Old 09-08-2011, 06:19 PM
NW 150's Avatar
NW 150 NW 150 is offline
NW 150 is starting off with a positive reputation.
I like it a lot, makes me want to do somethin like that with mine. good work!
Old 09-08-2011, 06:20 PM
Khyren Khyren is offline
Khyren is starting off with a positive reputation.
I see one thing missing... High beam indicator. Otherwise, bang up job man.
HELP!! need quick reply...5.4 Manifold replacement stud & screwed up drill out?!?! Kyle D 1999 to 2016 Super Duty 21 01-04-2017 08:01 AM
Manifold Stud Removal for dummies sammie0126 Excursion - King of SUVs 48 04-21-2015 08:37 AM
How to get off radius arm rivets - easy BroncoBilt 1978 - 1996 Big Bronco 0 11-27-2014 11:54 AM
Did the Hutch & Harpoon In Tank Mods HD Rider 1999 - 2003 7.3L Power Stroke Diesel 10 04-09-2010 07:53 AM
Dash Cluster Lights mod Welk49 1994.5 - 1997 7.3L Power Stroke Diesel 41 02-23-2010 09:24 AM
Tags
1965, 1979, 77, cluster, electric, enthusiasts, f100, f250, ford, gauges, guages, install, installed, lay, mechanical, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
