New Gauges Installed(pics) - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-12-2011, 08:23 PM
john81chevy john81chevy is offline
john81chevy is starting off with a positive reputation.
Looks great, and you can't beat the price either.
  #32
Old 09-12-2011, 08:35 PM
79_effie's Avatar
79_effie 79_effie is offline
79_effie is gaining momentum as a positive member of FTE.
That looks great. This is what I was thinking of doing, glad you posted so I could see it first!!
  #33
Old 09-13-2011, 12:08 PM
AJHEATING AJHEATING is offline
AJHEATING is starting off with a positive reputation.
I got the gauges installed last night and all was fine until i turned the dash lights on. When I pull the head light switch the right turn signal light comes on faintly. the left side blinker works, but the right side stays lighted and blinks about every 20 seconds.when I turn the light switch off all works perfect, got to figure this out before i can fiinish.
  #34
Old 09-13-2011, 04:46 PM
Tonyf250ranger Tonyf250ranger is offline
Tonyf250ranger is starting off with a positive reputation.
Dibs on one, they look great and I'd definitely want to do that with mine.
  #35
Old 09-13-2011, 04:49 PM
CueMan's 78 F-150 CueMan's 78 F-150 is offline
CueMan's 78 F-150 is starting off with a positive reputation.
I am in for one also. I like the final look, great job and let me know as there is no rush but lots of interest!
  #36
Old 09-13-2011, 06:23 PM
SG Jon SG Jon is offline
SG Jon is starting off with a positive reputation.
This looks sick! I now know what route I'm going with gauges... I can't get over how clean that looks. You did awesome.
  #37
Old 09-14-2011, 01:21 AM
got the light in my dash fixed it was the front left blinker ground was all rusted and not grounding. all fixed and installed tommorow I will take final pic of gauges in the light.
  #38
Old 09-14-2011, 08:01 AM
79bad4d's Avatar
79bad4d 79bad4d is offline
THE BEAST
79bad4d is starting off with a positive reputation.
I would be interested in one as well if you are able to make several!!!
  #39
Old 09-14-2011, 10:45 AM
lamar804's Avatar
lamar804 lamar804 is offline
lamar804 is starting off with a positive reputation.
^^^ME TOO!!!
  #40
Old 09-14-2011, 11:45 AM
How did you mount the radio plate? I ask because the PO cut the hold out, and hacked the plate behind it to Hell
  #41
Old 09-14-2011, 12:12 PM
the dash in mine was hacked too. there was about a 1/8" all the way around. I made 2 indentical plates with 3 holes put one on outside of dash and 1 on back then put the gauges in and sandwiched the dash inbetween them with the gauge brackets. I will look into making some of the plates for everyone
  #42
Old 09-14-2011, 12:27 PM
That sounds like a solid idea. Whats "AJ Heating" about? I think I've seen a truck with that on it somewhere.
I'd be down for a set too by the way. I have a long road before I can start swapping in better gauges but this is definately on the list.
  #43
Old 09-14-2011, 05:15 PM
AJ HEATING my initials and I run a sheetmetal shop for a heating company.
  #44
Old 09-15-2011, 10:09 PM
drove my truck for the first time and everything works good. The gauge I was hoping that worked was the air/fuel. It works ok, I got the idle set at optimal and can see it lean out were I have a flat spot so I can fix that hopefully. all in all, better gauges then I had and not better then some. I got what I wanted, and what I think a stock dash should have looked like. As long as I dont get bombarded I will start making and shipping some peices if anyone wants one, no special orders i dont have a shell to go by anymore. just send me a PM, thanks everyone.
  #45
Old 09-15-2011, 10:48 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
looks good,but!
How come you didn't clock the face like nascar for normal operating temps and all needles are straight up in normal operating conditions. gives it the racer's edge. looks great and just talkin smack. great job.
HELP!! need quick reply...5.4 Manifold replacement stud & screwed up drill out?!?! Kyle D 1999 to 2016 Super Duty 21 01-04-2017 07:01 AM
Manifold Stud Removal for dummies sammie0126 Excursion - King of SUVs 48 04-21-2015 07:37 AM
How to: 04-08 OEM headlights FX-R Projector HID retrofit. powerz69 2004 - 2008 F150 7 12-09-2010 09:33 PM
Did the Hutch & Harpoon In Tank Mods HD Rider 1999 - 2003 7.3L Power Stroke Diesel 10 04-09-2010 06:53 AM
Dash Cluster Lights mod Welk49 1994.5 - 1997 7.3L Power Stroke Diesel 41 02-23-2010 08:24 AM
Tags
1965, 1979, 77, cluster, electric, enthusiasts, f100, f250, ford, gauges, guages, install, installed, lay, mechanical, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
