Bleeding brakes on '89 F-250 (rear drums)
Old 09-07-2011, 08:46 PM
WINGNUT-'s Avatar
WINGNUT-
WINGNUT- is offline
A brake line on my '89 F-250 blew out a few days ago and I'm fixing it now. Once I get the new lines installed I will need to bleed the brakes. I have bled brakes before but only on my F-150 which has 4 wheel discs. Where are the bleeders located on the rears drum brakes on the '89? Will I need to remove both back wheels and remove the drums? Or are the bleeders easily accessible?
Old 09-07-2011, 08:52 PM
fdude64's Avatar
fdude64
fdude64 is offline
the bleeders are just above where the lines go into the backing plates/wheel cylinders
Old 09-08-2011, 01:58 AM
WINGNUT-'s Avatar
WINGNUT-
WINGNUT- is offline
Do I need to pull the drum for access? I did not see the bleeders behind the wheel.
Old 09-08-2011, 04:07 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
if they are broke off, you will need to replace the wheel cylinders, which involves removing the drums and brakes.
chukar
05-15-2016 10:00 PM
projectdagger
02-18-2013 11:27 AM
47FordEd
1947 and Older Ford Trucks
09-23-2012 10:01 AM
BPuller
06-16-2009 10:42 PM
marilyn
11-29-2004 01:17 PM
Quick Reply: Bleeding brakes on '89 F-250 (rear drums)
