Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-07-2011, 07:55 PM
Tony79shortbed Tony79shortbed is offline
Garage is empty, add now
Tony79shortbed is starting off with a positive reputation.
Tony Smith Tony****up
Is this a good block and rotating assembly to start with?
I am looking to get an almost complete engine from a guy pretty cheep.
Going to give him 100 and some old headers.
Was wondering if it was a good block and all to start a decent build for my truck.
Nothing too extreme. Still want it streetable and all but want about 300 to 350 horse.
He said it was from the mid to early 80s and I believe from a truck.
Cant seem to find anything about the casting number.
Just want to make sure it is not a smog engine or anything. I want some decent power.
Any help would be nice.
  #2 (permalink)
Old 09-07-2011, 08:00 PM
Update*****
Cam out of an 1986 F150 2wd lariat.
If that helps at all.
  #3 (permalink)
Old 09-07-2011, 08:17 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
When it comes to trucks everything between 1977 and 1987 is a low compression - low output smog motor, but that's mainly due to the heads and cam.. which can be changed pretty easily. If it's a 4bbl 351 from this era it's the 351HO and that's a good platform to build upon, swap on some better heads and a full exhaust system and 300hp isn't a problem. If it's a 302 you're gonna have to work a bit harder, it'll need a complete HCI combo to make decent power. In both cases the stock rotating assembly is more than capable of supporting this power level so nothing extra or even that special needed there, if you're rebuilding it just get it to stock spec for a late model engine('87+) to give it about 9-9.5:1 CR with most available cylinder heads.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1990 2.3L 5-sp Ranger 3.08, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
  #4 (permalink)
Old 09-07-2011, 08:26 PM
It is a 302 and that is all I want.
Basically what I was asking is if the stock assembly could hold it and if the block was alright.
Sounds like it should be alright.
I am changing the heads and everything else.
I read somewhere that it was a roller cam? Is that true?
Not looking for anything stock. I have my stock 79 with only 112 on the dash.
(3rd owner).
Looking to slam the truck on the 20s I have with some sattin black and red interior.
  #5 (permalink)
Old 09-07-2011, 09:39 PM
Conanski's Avatar
1990 Ford F-150
Quote:
Roller cam didn't appear in truck engines until 1992, though all blocks cast from 1987 on(E7TE casting number) will accept the factory roller cam assembly even if the motor didn't originally come with a roller cam.
__________________
  #6 (permalink)
Old 09-07-2011, 09:43 PM
Alright, that is good.
I would rather not do a roller cam.
  #7 (permalink)
Old 09-07-2011, 09:51 PM
Conanski's Avatar
1990 Ford F-150
They certainly work better.. the motor is much more free revving, but the parts are expensive.
__________________
  #8 (permalink)
Old 09-07-2011, 09:57 PM
Well, I would rather not because of the price.
Already having to either pay 500 for drop beams or about the same for a Crown Vic suspension set up.
  #9 (permalink)
Old 09-08-2011, 09:29 AM
Conanski's Avatar
1990 Ford F-150
Yeah compromises have to be made. It's no big deal in the long run.. you can still get roughly the same power level with a similar spec flat tappet cam.. at a 1/3 to 1/4 the cost.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
