Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-07-2011, 07:30 PM
PaasoRacing PaasoRacing is offline
Garage is empty, add now
PaasoRacing is starting off with a positive reputation.
500 or 600cfm carb for 390 in Snow Groomer
I just want your opinions on what would be a better carb for a 390 with a performer intake in a Thiokol Snow Groomer, a 500cfm or a 600cfm 4v. I am looking for good off idle torque and max rpm's will not be excessive... Most people seem to think the 600 is better for street applications but I am leaning to the 500 to keep things as crisp as possible. I just don't want to be under-carbed. What would the guys at the bar say when they find out I only have 500cfm... Thanks guys.
  #2 (permalink)
Old 09-08-2011, 07:34 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
500cfm 4bbl or 2bbl?
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
  #3 (permalink)
Old 09-08-2011, 09:18 AM
500cfm 4bbl
  #4 (permalink)
Old 09-08-2011, 09:26 AM
More specifically this Edelbrock Carburetor: Thunder AVS, 500 cfm, Square Bore, Manual Choke, 4-Barrel, Air Valve, Single Inlet. I like the idea of being able to tune in the secondarys.
  #5 (permalink)
Old 09-09-2011, 11:01 AM
DrainBramage DrainBramage is offline
DrainBramage is starting off with a positive reputation.
Bump for you, hopfully someone who has used a 500 4v & 390 can can jump in on this.
From a purely technical standpoint, if we assume 80% volumetric efficiency, a 500CFM carb runs out of air & fuel on a 390 @ 5500rpm. With a 600CFM on tap, we are looking at 6650rpm.
Calculate Required CFM Of Carburetor
Personally, I have a 600CFM Holley 4160 that I previously used with the 302 in my Mustang that will find a new home sitting on top of the 390. Throttle response on the "little" 302 was fine but it was definitely too much carb. I expect response on the 390 to be just fine... after I get it dialed in. I also have a 600CFM Autolite 4100 I plan on playing with, but it needs some work. Secondary tuning will be key. I'll never spin my 390 up to the 6650rpm, but that shouldn't matter with a vacuum secondary.
Seeing as you are running this thing in the snow, I'd be very careful with the jetting. Depending on your temperature differential between winter and summer, and things can get interesting. Tune it now and she will run lean come winter time when the air gets cold and thick. I have zero experience with the Edelbrock/Carter carbs, but I know there are formulas out there for up-sizing and down-sizing Holley jets based on altitude and temperature.
Hope this helps!
__________________
1973 F250 2wd Camper Special - 390FE, 600cfm Autolite 4100, DSII w/MSD 6A, NP435, Dana 60 4.56:1 open - haulin' beast (66.6k mi 7/24/11 )
1966 Mustang - built 302, 480cfm Autolite 4100, B/W T5, Currie 8" 3.55:1 LSD - in pieces
1974 Bronco - 302 2v, C4, D20, D44, 9" - 'consulting mechanic' (Brothers project)
1974 Triumph TR6 - 2.5 I6, Twin ZS175CD carbs, 4spd, Panasport 15x6 - the 'fun' project
Tags
20l, 360, 390, 600, built, carb, carbs, carburetor, cfm, cyliner, engine, fe, ford, groomers, home, people, snow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
