BOUGHT IT! '51 F-1
BOUGHT IT! '51 F-1
I'll upload more pics to my '51 album in a few minutes. Very excited and very nervous. My first challenge will be replacing the differential/rear end. I am told by the guy I bought it from that I should not attempt this myself. I am not a "car guy" but am also not afraid to become one. And I can read directions. But I am getting ahead of myself. I'll post some pics.
t & c
t & c
2 Questions: Why do you need to change the rear end? And why did the guy tell you you can't do it yourself? It's not a difficult job at all, one that would be fairly simple to begin your quest. Did he offer any explanation to his reasoning? I'd be curious to know if he had a reasonable warning, or just trying to get a job (more money) out of you.
Congrats on your acquisition.
Congratulations! You have a nice looking truck. Sounds like your mechanic guy is an a$$. It's not hard to change out the rear end. It's a bolt-in procedure. Look for a 9" rear end from a 57-67 F100. They're a direct bolt-in. 68-72 will require some modification to the spring perches.
Good luck with your project and ask a lot of questions.
What exactly IS a 9" rear end? What is the 9" measurement? That cannot possibly be the diameter of the axle can it?
And do I WANT a 57-67 rear end? If I am gonna mess with this, should I get something newer?
Is the diff a separate part from the rear end, or is it all one deal?
I posted a more specific thread yesterday about swapping out the rear end and I have gotten the gamut of answers--from there is no bolt in swap, to your answer that there is, in fact, a bolt in swap. I am rather confused. I am going to try to find a shop manual so at least I have a starting point...
I want this vehicle for a daily driver eventually (for my kid) and to be OK at highway speeds if needed. Not on the freeway daily, but I don't want it to redline at 45 mph in third gear, ya know?
I eventually want this truck to be a DD for my son (14) and to be able to handle highway speeds if required. Not daily or anything, but I don't want it to top out at 45mph.
Do I want something as new as I can get so there is minimal wear on it? Or are old ones fine? I saw your link to the guy selling an original '51 rear end, but again, do I want that, or am I just buying myself problems?
Why can't I just replace the differential? Is that and inseparable PART of the axle?
I need to get a shop manual and a parts catalog so I know what the heck I am starting with. Where can I get a shop manual?
Thanks,
tyler
Thanks PanelMan. No my mechanic is not an a$$ but is rather pessimistic about lots of things and kind of an alarmist. So I try to temper what he tells me with other advice. i am not a car guy, and he knows it, so in his defense, I think he is trying to protect me from myself: ) But I fly $40 million jets for a living, so I think I can figure this out with enough patience and study. So....
People are generally meaning the same thing when they are referring to a differential and a rear end. I guess technically one can claim that the differential is the assembly housed in the rear end housing. Generally there are 3 different types of differential. A typical "single legger", meaning the differential allows the power to be transmitted to only one wheel... Limited slip differential, meaning the differential has clutch built in where it transfers the power to both wheels... and a spool, that lock the wheels in sink. When most people say "Posi" traction, they are referring to a limited slip.
Anyways, if you are looking for a newer rearend, then look for something with the gear ratio of 3.5 - 3.7 to 1. It will cruise better than the typical 3.9-4.11 stock set up. Also I noticed somewhere on the forum that lists the rear end width. Just make to get something that is close to the stock width and you will be fine.
