No Start - Low ICP New IPR/CPS/Fuel Pump
#31
#32
Truck is currently dead in Santa Cruz, CA. Once I get it running I could drive it somewhere. By custom tuner, do you mean a shop that will put it on a dyno and create a custom chip for my truck? I've done that on my motorcycles before but not on a truck.
#34
With the posts here I have read, most just choose 4 set ups and with the most common brands and most only uses 1 or 2 of them, so is your choise.
#35
Update:
Installed new Adrenaline HPOP $400ebay (Joey was backordered)
Now it will start in unison with the blinking WTS light.
If I disconnect Signal leads from GPR, WTS light doesn't come on and AE will not communicate with PCM, and it won't start.
I figured the GPR was bad, so I replaced with a 586-902 which came as a white rogers brand rather than a stancor. With that relay WTS doesn't come on and no smoke like it's trying to start, and AE won't communicate with the PCM.
So unless the new 586-902 relay is bad and messing with PCM (not sure how though) along with the stock relay which actually seems to give PCM some life, I think my PCM is indeed shot.
Any ideas?
Any ideas?
#36
That_LHD_Diesel
07-21-2017 12:56 PM
SunBum
22
08-12-2016 06:02 AM
60RatRod
02-25-2011 06:50 AM
