2000 F-53 motor home chassis
Im hoping someone can help me. I have a 2000 F-53 chassis with 6.8 V10 motor. Started the other day and was running rough. Check engine light came on. No power to pull out of driveway on slight incline. pulled codes and it said pack B, C, D, E were misfiring. i jumped the gun and replaced and didnt fix the problem. I have no spark on the entire right bank of plugs (pass side) I ran continuity test and power test to the packs and pins and they seem ok. thinking probably the PCM is bad. I did see some mouse droppings around the engine cover but found no wires chewed at all! i really checked all wires and was hoping to find something. Question, would the PCM have a chip that covers one whole side of the engine that could have gone bad or am i missing something. Big thanks to anyone who can shed some light Roger
I moved your post to the v10 forum.
Yes, I do believe the PCM has a separate circuit for each bank. The good news is, that I think it has a single ground going TO the PCM for each bank. The PCM grounds the coils to fire them, and it might use a separate ground for each bank. Keep looking for mouse teeth-marks
And it sounds like you already checked for +12V at the red wire at the coils with the key on?
Each bank on the V10 has a common battery power feed, but each COP has a separate low side connection back to the PCM so the PCM can fire each coil in sequence. There is no single ground for each bank shown on the schematics.
Nope, not a cam sensor.
If you do have B+ on the COPS but no ignition pulse from the PCM (Verify BOTH!), I'd suspect an internal PCM failure.
If doing your own trouble shooting of the vacuum and/or electrical systems I'd suggest an EVTM from Ford---not sure if the F-Series or E-Series would be closest to your chassis though.
I find these all the time in great condition typically for $20 or less on eBay------I don't leave home or open the hood without one these days!
turns out, i had the info with me on another sheet obtained from Ford. Im showing PCM with 7 grounds (pin 51,3,23,24,76,77,103) going to G103. pin 25 to G200 and 33 going to G204. I checked continuity on all pins and they were grounded well! Im in the auto glass business, and know just enough about this to cost me a small fortune. I think im convinced it is the PCM. Now just where to find one since Ford made it obsolete! We were supposed to use the MH last weekend, couldn't fix, so ended up in a tent. wanting to use next weekend so looking for new or quick repair shop. cant find anyone in St. Louis area who repairs PCM's any suggestions? Thank you again for all the great advice. Roger
