1994 F150 Transmission Hard Shiftin - Ford Truck Enthusiasts Forums
Old 09-07-2011, 12:29 PM
redbug's Avatar
redbug redbug is offline
redbug is starting off with a positive reputation.
Hello,
I have a friend with a 94 F150, 302 engine, Automatic, 4x4. He was driving down the road the other day and it banged into gear at high rpm when it used to shift at lower RPMs. It also lit up the abs light and the speedometer stopped working.
He found that the rear end speed sensor wire was broken and has repaired that. That did nothing for the shifting. But, that did correct the abs light and non-functioning speedometer.
After that incident, it still does not shift right. What could be the cause.
Regards,
redbug
Old 09-07-2011, 01:34 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Ford Fuel Injection How To Run a Self-Test Here is a link on how to get any trouble codes. Maybe try that to pin-point the problem.
Old 11-23-2011, 10:00 AM
redbug's Avatar
Still no ideas on this transmission. When it goes into each gear it revs very high and then BOom into gear. Once in gear its fine and does not slip. Please help.
Old 11-23-2011, 10:19 AM
Did you check for trouble codes? Probably going to be 3 digit codes.
Old 11-23-2011, 10:31 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
pull that sensor out of the rear diff and clean it off. he should also trace that wiring back to make sure there are not any further breaks in the wire or spot that are grounding onto the frame. Has he unhooked the battery for 10-15mins and then seen if things clear up?
gotta pull codes, TPS issues may cause shifting problems, same goes for the mlps.
Old 12-05-2011, 07:40 AM
redbug's Avatar
Thanks everybody for the suggestions.
My friend had his mechanic come over with the error code reader.
"Shift indicator problem" was read out.
They traced the wires. One wire had 5 volts going to it and zero coming out which indicated a broken wire in the harness.
Right next to the front plug on the transmission they found a wire that was broken in half. Soldered it up, and everything is fine!
Regards,
redbug2
Tire Recomendations? redbug 1999 - 2003 7.3L Power Stroke Diesel 17 01-05-2016 08:30 PM
Diesel oil in center of engine. redbug 1999 - 2003 7.3L Power Stroke Diesel 6 08-28-2015 04:59 PM
Where is the block heater cord? redbug 1999 - 2003 7.3L Power Stroke Diesel 5 02-03-2012 08:45 AM
1985 F250 off my insurance... redbug Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 08-11-2011 10:36 PM
1995 f-150 speedometer boilerperson 1987 - 1996 F150 & Larger F-Series Trucks 7 07-19-2003 08:51 AM
Tags
1994, 1996, 94, bronco, codes, f150, ford, hard, location, mlps, mpls, problems, shift, slipping, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
