how to replace starter drive - Ford Truck Enthusiasts Forums
Old 09-06-2011, 07:11 PM
WebMonkey WebMonkey is offline
WebMonkey is starting off with a positive reputation.
1964 f100 w/292 v8
so i've pulled off the starter and found the starter drive broken in half.
well the gear part anyway.
i can see the 'drift pin' at the top of the shaft, this obviously holds all the goodies on the shaft.
i've got the new part on order from napa but i have no clue how to get that pin out. i can't seem to 'compress' the top washer any at all to expose the pin enough to knock it out.
anyone have experience replacing the starter drive?
thanks
'monkey
Old 09-07-2011, 05:09 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
You have the Bendix inertia type of starter drive (C2AZ-11350-C ~ Motorcraft SD-132), it comes as a one piece assembly: Includes the gear, housing and large coil spring.
It's retained on the starter armature shaft with the "drive pinion" (drift) pin (C2AZ-11365-A). You have to 'unwind' the starter drive to gain access to the pin...to drive it out.
It's a snap to unwind it, but...when this drive unwinds, it can be a PITA to get it back into position.
Old 09-07-2011, 09:49 AM
thanks for the tip.
i gave a 'cursory' attempt but hopefully when the new assembly arrives, i'll be able to unwind it and expose the pinion.
'monkey
Old 09-07-2011, 10:51 AM
Grab the housing with one hand, hold it firmly, the coil spring with the other, then turn the spring...the drive unwinds.
But it takes muscle to reverse the process.
1979 F250 7.5L Starter issues dbail3 Electrical Systems/Wiring 3 09-18-2014 08:07 PM
Carb Linkage alamartina 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 01-07-2014 03:44 PM
1989 Ranger 2.9 starter issues countrytech Ranger & B-Series 6 11-26-2012 12:45 AM
Starter drive question turnrjr 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-04-2009 09:25 AM
How do I replace a starter drive assembly spring BFOOTER03 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-02-2008 08:30 AM
Tags
change, drive, fix, flathead, ford, gear, motorcraft, procedure, removing, replace, replacing, sarter, sd132, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
