1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Running lights and instrument cluster lights out.
Old 09-06-2011, 03:40 PM
h0rs3p0w3r's Avatar
h0rs3p0w3r
h0rs3p0w3r is offline
Just the other day I fired the truck up and turned the lights on and my headlights came on but my gauges didn't light up. I figured I probably had a blown fuse or something so I didn't bother checking it immediately and decided to drive home anyways and on the way home I got a phone call saying that my running lights weren't working either. Front or rear. Still have brake lights and turn signals but no running lights. I've checked all the fuses and none of them are blown and I'm going nuts trying to figure out what is wrong before I get a ticket. I'm tired of lightly holding the brake as I pass by cops at night. Anyone have any ideas what could be causing this issue?
Old 09-06-2011, 05:13 PM
Pili's Avatar
Pili
Pili is offline
Lights on and no gauge lights normally means the dimmer is rolled all the way down. i don't have daytime running lights on mine but they do turn themselves on when its dark. The darkness sensor (not sure what the proper name is) could be bad. Did try turning on the headlights? And have you done a continuity test on the switch?
Old 09-06-2011, 05:18 PM
h0rs3p0w3r's Avatar
h0rs3p0w3r
The truck is an 04 F250 Super Duty. There isn't a darkness sensor on it. And the dimmer switch isn't rolled down. The switch has three settings. All the way to the left is off. Second setting is running lights and dash lights come on. And third setting is same as the second along with the headlights. Headlights work just fine but just the running lights and dash lights aren't working.
Old 09-06-2011, 05:27 PM
Pili's Avatar
Pili
Pili is offline
Ohh ok, you had me a little confused. Your talking about the parking lights. Do a continuity test on the switch. Just because the other lights are working doesn't mean the switch is good.
Old 09-08-2011, 12:53 AM
Kid Geoff's Avatar
Kid Geoff
Kid Geoff is offline
Did u just install an aftermarket radio?? Check the orange or orange with white wire isnt grounded behind the stereo. Something in your running light circuit shorted or you have a bad switch...
Old 09-08-2011, 06:49 AM
shorebird's Avatar
shorebird
shorebird is offline
Have you done a fuse check?
Try #17.
Old 09-08-2011, 09:47 AM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
Check the fuses with a test light or a continuity meter also. Just because it doesn't appear blown doesn't mean it is a good fuse.
Old 09-08-2011, 11:27 AM
Wisebuck's Avatar
Wisebuck
Wisebuck is offline
Similar issue when I got my '04 and found that the main elec bus connector for multi function switch on steering column was almost completely disconnected. From bouncy roads I guess. Reconnected it and everything worked like new. I pan-tied it so it won't come apart again. Easy. Check that first. Tilt steering will pull it apart too. There is a thread for the steering column take apart.
Old 09-08-2011, 09:54 PM
Ford-Trucker84537's Avatar
Ford-Trucker84537
Ford-Trucker84537 is offline
Just had this problem, it was my headlight switch
Old 09-25-2011, 04:45 PM
dukkie's Avatar
dukkie
dukkie is offline
Who has a wiring diagram for this switch (2005 f250) ?
Old 08-11-2016, 08:48 PM
Pocketlint's Avatar
Pocketlint
Pocketlint is offline
You should be able to locate that diagram I would think here ....go to www.bbbind.com and go to and mouse over to technical information, from there select the drop down menu and select TSB & wiring diagram database ( you will have to register for a free account) then it is matter of putting in the info for your truck make, year, model, style, engine and then you should be able to find what your looking for.
Old 08-12-2016, 07:37 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Go to this thread, follow the search links in my post. The 04 diagrams, which are the same as for the 05, are in one of those threads. I saw it yesterday while making that search.
https://www.ford-trucks.com/forums/1...s-blowing.html
There's your trail of breadcrumbs, you'll have to follow it.
Old 10-10-2020, 12:43 AM
Jaydee91's Avatar
Jaydee91
Jaydee91 is offline
my truck didn’t have a radio in it when I got it but the wiring was still in it when I got my new radio I used the harness it came with but noticed the harness that was left in my truck had a orange wire while the new radio did not so I taped the orange wire off coming from the factory plug could this be why my lights and cluster are not coming on?
6.9idiatsturbo
18
08-15-2016 05:54 PM
Wicked Endings
13
11-09-2010 06:54 PM
ebaugh90
05-08-2009 12:45 PM
whitesdford
07-26-2008 11:08 AM
$Simpleman76
03-22-2007 06:29 PM
Quick Reply: Running lights and instrument cluster lights out.
