FRONT GAS TANK NOT WORKING - Ford Truck Enthusiasts Forums
Old 09-06-2011, 03:13 PM
1badshovel 1badshovel is offline
1badshovel is starting off with a positive reputation.
Ok heres the story 1994 ford f250 7.5 4x4 dual tanks I used both front and rear tanks regualrly than one day front tank stoped working fuel pump doesnt turn on when key is in the on postion now you can hear the rear turn on when switched to rear tank took off pigtail connector to front tank no power at all to tank took off swith in dash no power there either good relay and fuse funny thing is with swith turned to front fuel guage reads correctly switch to rear reads correctly Im stumped because oveiously Im getting power to the switch but checked wires at switch and cant get any power or at front tank but power to rear.
Old 09-07-2011, 05:50 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Bad selector switch on the dash.
Old 09-07-2011, 06:07 PM
I replaced switch on dash today now I have power to the tank but fuel pump still doesnt kick on Im wondering if It might also be the fuel selector valve under the truck or just a bad fuel pump.
Old 09-07-2011, 08:47 PM
subford's Avatar
First off you do not have a fuel selector valve under the truck so I do not think that would be it.
I would guess the bad fuel pump took out the selector switch on the dash.
Old 09-07-2011, 10:41 PM
Thanks alot for the help Im going to try a new fuel pump and see what happens Ill keep you posted.
Old 03-18-2012, 11:13 PM
paine2 paine2 is offline
paine2 is starting off with a positive reputation.
Thumbs up fuel problems
your not going 2 believe this 1992 ford f250 4x4 iv grown up playing in junk yards thought i new it all till now no power to the front or rear fuel tank every this is working right on the dash but cant hear eather pump pressure up checked relays well checked every thing even the safety switch on the right side passenger side it was the daRn ignition switch box on the steering column hope this will help some one DAve
Old 02-01-2013, 03:44 PM
Forger Forger is offline
Forger is starting off with a positive reputation.
That damn ignition switch fouls all kinds of things up.
Fuel Switch Wiring reno138 1987 - 1996 F150 & Larger F-Series Trucks 10 03-12-2014 03:26 PM
Question on fuel selector valve - dual function reservoir SSellers 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 12-24-2013 01:47 AM
gas tank problems Jeffery the first 1987 - 1996 F150 & Larger F-Series Trucks 1 03-08-2011 06:30 AM
Fuel Selector Valve? 1986 F-350 w/460 mdm350 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 03-16-2010 10:52 PM
88 EFI econoline dual tank issue alvaroguillen 1968-2013 Full Size Vans 8 02-04-2010 11:25 PM
Tags
1994, 1996, 94, 95, f150, f250, ford, front, fuel, gas, switching, tank, tanks, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
