Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-06-2011, 01:05 PM
buzzer691000 buzzer691000 is offline
1960 Ford F-100
My Garage
buzzer691000 is starting off with a positive reputation.
motor swap
I have an 1984 ranger with a 2.3 l with only 30,000 miles since the rebuild and now the tranny is starting to go out. I have really been wanting to switch motors to a extended cab or a Bronco II. Not really sure if that is a possible swap I really use the space a for hauling the kids around. any advice would be great.
  #2 (permalink)
Old 09-07-2011, 11:03 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
I don't see any reason why that wouldn't be possible...the 2.3 has always been an available motor in the Ranger. Your mounts and such should be a straight bolt-in right up to 1992. After that they changed the body style and I believe the frame was redesigned, though your motor would still work. My sister has a '93 with a 2.3 in it, though it's EFI rather than carbed.
As I recall the extended cab option was available on the Ranger beginning in '86.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 09-07-2011, 12:38 PM
1960 Ford F-100
My Garage
Thanks for info I just wasn't sure how common the 2.3 was in the Bronco II heard the mostcommon motor for them was a 6 cylinder.
  #4 (permalink)
Old 09-07-2011, 02:16 PM
TigerDan's Avatar
1968 Ford F-250
Probably not too common in a BII but since the front is the same as a Ranger it should be a bolt-in swap. Might be a bit sluggish though due to the extra weight. Your current truck should weigh in at around 2800 lbs. while the extended cab comes in at about 3100 and the BII is almost 3400. You could shave that some if you can find a fairly rare 2WD BII if 4WD isn't important to you, or you could possibly convert a BII to 2wd using Ranger components.
__________________
Tags
ford, motor, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
