460 power steering bracket
Old 09-06-2011, 12:08 PM
chizzy matt's Avatar
chizzy matt
chizzy matt is offline
Question 460 power steering bracket
would a 460 engine with a/c have a different power steering bracket than a non a/c equiped engine?
Old 09-06-2011, 12:41 PM
jwmayfield's Avatar
jwmayfield
jwmayfield is offline
which is yours I have a/c
Old 09-06-2011, 01:29 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Same with/without A/C ~ Assuming this is a 1978/79 F100/350 460.
DOAZ-3C511-F .. P/S Pump Support Bracket.
1973/79 F100/350 460 / 1970/76 Ford/Merc Passenger Cars 429/460.
D8TZ-3A732-A .. P/S Pump Adjusting Bracket
1978/79 F100/350 351M/400/460 ~ Use w/P/S pump with plastic reservoir.
Please, when asking questions, list all the pertinent info: year, series, engine size, 2WD or 4WD.
Old 09-06-2011, 04:41 PM
chizzy matt
My truck is a 78 F150 4x4. The power steering pump has a plastic resourviour and it adjusts by loosening the 3 bolts on the bracket and turning the adjustment screw. The reason I ask is the placement on the power steering bracket for the a/c belt idler pulley. At this time that is my only x factor on making my system work like it was meant too. I was working off of pictures of ones and made a spacer and bought a pulley which is the same diameter as the upper a/c idler pulley. My lower pulley is too far to the passenger side to engage the belt. Trying to figure out why?
Old 09-06-2011, 04:52 PM
NumberDummy
You need to see the pic of the P/S setup...ask mikeo0o0o0 to post this:
Illustration Section 36, Page 26. Shows the correct brackets and the A/C idler pulley that bolts to the P/S pump support bracket.
Did you swap a 460 into this truck? mikeo0o0o0 posted the parts catalog pic for a 1973/79 F100/350 460 compressor and idler pulleys.
Old 09-06-2011, 05:03 PM
chizzy matt
No I purchased it that way and the next truck I buy will be one that is bone stock!
mycam8u2
02-09-2010 10:50 AM
460man
04-21-2006 01:00 AM
brennamp
06-03-2005 06:26 PM
olfordsnstone
03-15-2005 03:29 PM
Waltman
09-13-2004 12:41 AM
Quick Reply: 460 power steering bracket
